5.7 Incorrect oil dipstick - JeepForum.com
 5Likes
post #1 of 28 Old 06-14-2016, 07:00 PM Thread Starter
Rich-
My 2013 Jeep Grand Cherokee 5.7 came from the factory fitted with the wrong dipstick.
the incorrect dipstick part number ends in C, the correct one ends in D. verified by the dealer but they think i am crazy, but was not going to argue with them over the $16 the new one cost.
the new one is the longer
7 Qts installed with the incorrect dipstick reads right at the 2nd D on ADD, it is hard to see in the pics.
7 Qts and you can see that with the correct dipstick is spot on the full mark
here you can see the old dipstick with the incorrect part number ending in C next to the new correct part number seen on the label
thanks to all in my original thread https://www.jeepforum.com/forum/f309/...ndrum-3782970/ maybe this can get made into a Sticky to help others.
GoPlzGo likes this.
Rich- is offline
post #2 of 28 Old 06-14-2016, 07:12 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Thanks, nice write up. Added to the maintenance/repair index (a sticky thread).
All 5.7s are made in the same Mexican factory. So you could envision that they pulled the wrong dipstick off the shelf for the Jeep 5.7. But I think it was more likely a supplier problem. A batch of dipsticks (or perhaps tubes) for a different tube application was stamped with the wrong part number. It happens.
My 2011 has AD, but the dealer does my oil changes and they may have changed it without mentioning it.
Rich- likes this.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 28 Old 01-13-2017, 08:47 AM
allen03jeep
Just got an oil change at the dealership. Verified I have the incorrect dipstick on my 2014 5.7L Overland. Ends in C and was showing a qt low. Ordered the new replacement. Right on the money. Thanks everyone!
allen03jeep is offline
post #4 of 28 Old 01-13-2017, 09:34 AM
jim_in_PA
2012 WK
Yes, this is a "known issue" with the earlier year JGCs, but not many owners "know" about it...
2012 JGC Summit Hemi
2016 Subaru Outback Limited
2011 Subaru Outback Limited
jim_in_PA is offline
post #5 of 28 Old 01-13-2017, 11:13 AM
mx71
2013 WK
My 2013 also had the incorrect dipstick.
mx71 is offline
post #6 of 28 Old 01-13-2017, 11:39 AM
biker2k
2012 WK
add it to the list of mistakes on my vehicle...
never thought to check but I just did and mine ends in c
wasn't there something about the tranny dipstick as well..
biker2k is offline
post #7 of 28 Old 01-14-2017, 05:50 AM
BigNunz6
BigNunz6's Avatar
2015 WK
My 15 GC SRT also had a wrong dip stick. Learned about it before I had a oil change done.
If you like it, buy it!!!!
BigNunz6 is offline
post #8 of 28 Old 01-15-2017, 01:33 PM
TypeRod
The dealer I went to said the tech could only find the TSB for the SRT8 JGC for the incorrect dipstick, I asked him to check again and he refused. So I went and ordered the dipstick from them and had to call FCA and had a case filed and FCA sent me a check. Never going back to that dealer or at least the SA, lol.
TypeRod is offline
post #9 of 28 Old 01-15-2017, 03:24 PM
Raptor
This f*ck up effects all 2011~2015 WK2's equipped with 5.7L hemi engines.
Here a link to the TSB; The SRT hemi's also came with the wrong dipstick but that is covered under a different TSB.
http://www.wk2jeeps.com/tsb/tsb_wk2_0901015.pdf
Notice how it only covers 2014~2015 model years...that's because the 2011~2013 models that also came from the factory floor with incorrect dipsticks are no longer covered under the 3yr/36K mile bumper to bumper warrantee!
MadMikeX3 likes this.
Raptor is offline
post #10 of 28 Old 01-16-2017, 10:48 AM
Heel2toe
Wow I have officially seen it all! I just changed my GF's oil on her 2011 with the 5.7 and put in close to 7.5qts. Just to confirm if her car has the dipstick ending in C that is indeed the incorrect dipstick and the one ending in D is the correct replacement?
Also, you're telling me that if the car did come with the C dipstick its the wrong one yet Ill have to fork over the $16 for it?
Heel2toe is offline
post #11 of 28 Old 01-16-2017, 10:53 AM Thread Starter
Rich-
Correct
Rich- is offline
post #12 of 28 Old 01-16-2017, 10:57 AM
Heel2toe
That is borderline insane! This also means I should drain out some oil...How can Chrysler possibly justify this and put this on us?
Heel2toe is offline
post #13 of 28 Old 01-16-2017, 10:57 AM
Wavicle
2011 WK
Geeze... this explains why I always complained that after a dealer-performed oil change I was 3/4 quart low! I would fill it each time to compensate. Looks like I should get a new stick for my 2011 Overland (purchased new Oct 2010 and has about 45K miles). Thanks for the info
Wavicle is offline
post #14 of 28 Old 01-18-2017, 11:29 AM
Pitchlynn
2014 WK
I ran across this a few months ago and jeep replaced mine with the correct one while I was covered under certified pre-owned warranty. The TSB on this also mentions the blue smoke on start up issue with the Hemi which I experienced twice while being overfilled on oil due and to the wrong dip stick and parked uphill on my driveway. I haven't seen the smoke on startup since I had it replaced and removed some of the old so it had the right amount.
Pitchlynn is offline
post #15 of 28 Old 01-18-2017, 11:26 PM
qqi9qqi9qqi9
2014 WK
Just checked ,my 2014 also have the wrong dip stick
2014 Grand Cherokee Overland 5.7L Hemi V8 4x4
2012 Grand Cherokee Laredo 3.6L VVT V6 4x2
qqi9qqi9qqi9 is offline
