2019 Map Update Question - JeepForum.com
post #1 of 17 Old 09-18-2019, 04:42 PM Thread Starter
SEMIJim
2015 WK
Hi All,
I took advantage of the recent $50 discount on a map update for my 2015 WK2's Uconnect system. I now have it in hand. I've a question: Rather than leave the engine running, at idle, for an hour or more, can I simply place the ignition in "Run," leave, lock the doors, and come back to check it from time-to-time? Will it stay in "Run," left on its own, for the required time? With my keyfob perhaps out of range?
I'm certain I've seen this discussed before, but I'll be darned if I can find it, now that I actually need it
SEMIJim is offline
post #2 of 17 Old 09-18-2019, 07:31 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Unattended, the Jeep will sleep at some point, maybe 10 minutes. I think if you leave a rear door open it takes longer to sleep. It has been discussed before, but I can't find it either. The process may be different for different radios.
My understanding is that, for best results, leave the engine running when the software is being updated or you have to start over. The map update can be interrupted and it will just continue where it left off.
Do not mistake temptation for opportunity
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 17 Old 09-19-2019, 06:09 AM Thread Starter
SEMIJim
2015 WK
Thanks, CC. I'll just go out, put the Jeep in "Run," lock the doors and walk away. See what happens. In fact: I'll do that right now.
Update #1: It stayed on for at least twenty minutes, but less than thirty. Now doing test #2: In "Run," doors unlocked, keyfob left in Jeep.
Update #2: Stayed on more than thirty minutes, but less than 45. Now doing test #3: In "Run," driver's side back door open, keyfob with me.
Update #3: No improvement over the last test. I'll try going out and opening/closing the door every fifteen minutes.
Update #4: *sigh*... I guess leaving it running is the only option. That really sucks, IMO
SEMIJim is offline
post #4 of 17 Old 09-19-2019, 08:39 AM
2014RedHemiGC
2014RedHemiGC's Avatar
2014 WK
That’s where a battery tender comes in handy. I leave mine on during updates while on the tender for no battery drain. No wasted fuel!
2014 Deep Cherry Red GC 4X4 V8 QDII
2012 Crystal Red Cadillac CTS-V Coupe
2011 Crystal Red Chevy Corvette Z06/Z07
2014RedHemiGC is offline
post #5 of 17 Old 09-19-2019, 08:42 AM Thread Starter
SEMIJim
2015 WK
I have one. Battery drain isn't the problem. Problem is I've found no way for the thing to stay on short of leaving the engine running.
And wasted fuel isn't my issue with leaving it running. Sitting on idle for sixty minutes isn't good for the engine.
SEMIJim is offline
post #6 of 17 Old 09-19-2019, 09:06 AM
ColdCase
ColdCase's Avatar
2011 WK
I think OBD scanner software like AlfaOBD or AppCar can set the Jeep to run mode (maybe called update mode) for an extended time.
ColdCase is offline
post #7 of 17 Old 09-19-2019, 09:27 AM Thread Starter
SEMIJim
2015 WK
I've already spent more than the time to apply the update trying to figure out a way around that. I'm just going to leave it running and be done with it.
Maybe some day auto manufacturers would get into the 21st century.
I used to be in the U.S. auto-related industry. You have no idea how happy I am I no longer have to work with those dinosaurs.
SEMIJim is offline
post #8 of 17 Old 09-19-2019, 11:56 AM
GPSBob
2015 WK
FYI, when I updated the maps on my 2015 a couple of years ago, it took 90 minutes (engine idling, as you have discovered). For much of the process, there was no indication that anything was happening. Perhaps they've improved on that with this latest update.
GPSBob is offline
post #9 of 17 Old 09-19-2019, 12:04 PM
ColdCase
ColdCase's Avatar
2011 WK
There have been quite a few usability improvements since model year 2015, as well as a few missteps with over the air updates.
ColdCase is offline
post #10 of 17 Old 09-19-2019, 03:45 PM
2014RedHemiGC
2014 WK
That’s interesting and like ColdCase says, it must be different for the various radios. My ‘14 is the Model RA4 - Uconnect™ 8.4AN (with navigation) and does not time out in the “RUN” position as long as the tender is supplying power.
post #11 of 17 Old 09-19-2019, 04:40 PM
ColdCase
ColdCase's Avatar
2011 WK
Dunno, the radio update TSBs require 2011-2013s ignitions to be on only, but recommend a charger be attached to maintain the battery voltage. 2014 and newer went to USB updates, I think, and the TSBs require the engine to be running during the procedure, the time seems to varies by model year and update. All seem to suggest not opening or closing doors or touch the radio until directed to do so.
ColdCase is offline
post #12 of 17 Old 09-19-2019, 07:50 PM Thread Starter
SEMIJim
2015 WK
Same for me, with this update. The display suggested it'd be around 70 minutes. It was at least 90.
They have not.
Thanks, everybody, for your feedback!
SEMIJim is offline
post #13 of 17 Old 09-27-2019, 10:28 AM
Streams
Hi All,
Oh wow, I did not know that we had to pay for updated maps. I have a 2018, will it tell me on the display when new maps are available?
Streams is offline
post #14 of 17 Old 09-29-2019, 11:08 AM Thread Starter
SEMIJim
2015 WK
This is normal for factory navigation systems, TTBOMK.
Dunno. My 2015 did not. I got emailed notifications of a sale from FCA. Repeated notifications.
I did get a notification of some OTA firmware updates to UConnect a couple days ago, when I shut off the ignition after parking when I got home, though. First time I'd seen that.
I'd forgotten all about that. Everything seemed to be working correctly when I went out to fetch carry-out, last evening, so I guess nothing got broken
SEMIJim is offline
post #15 of 17 Old 09-29-2019, 11:45 AM
Mogul
Are there noticable improvements or updates to the new nav maps?
Mogul is offline
