2019 Grand Cherokee High Altitude swaying problem - JeepForum.com
 4Likes
  • 1 Post By ColdCase
  • 3 Post By Fast55
post #1 of 11 Old 03-13-2019, 12:12 AM Thread Starter
Kaiser1983
Hello, I just purchased a 2019 HA. It has less than 200 miles. I was driving in the expressway today and my Jeep had a difficult time staying straight at higher speeds (60-80 mph). A few times the vehicle would pull to the left and even a slight correction to the steering wheel make the car over correct to the right. I did notice I had about 45 psi in the tires which is high as I learned they are supposed to be at 36 cold. I have read post on other site about bearing, shocks, etc but this is literally a brand new car. Any ideas? Thank you very much.
Kaiser1983 is offline
post #2 of 11 Old 03-13-2019, 06:48 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
They fill to high pressure for transport, the dealer prep was suppose to correct that.
Sounds out of alignment or a defective/loose suspension component, have the dealer look at it. These jeeps do wander around a little more than the typical car, however. Wide tires, compliant suspension.
BigTizzie likes this.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 11 Old 03-13-2019, 03:23 PM
6t9chgr
2017 WK
I know when its very windy out, mine gets that swaying feeling at times as well....thing is like a brick with wheels....not the most aerodynamic thing out there.... LOL
6t9chgr is offline
post #4 of 11 Old 03-13-2019, 04:00 PM
Fast55
Fast55's Avatar
2017 WK
Is it possible you are feeling the lane keeping assist? Scared the hell out of my wife the first time she felt it in her Pacifica and although she insisted on every bell and whistle, she now turns everything off.
2017 Trailhawk
Active Safety - Luxury group - Blind spot detection
Hemi
Rock Rails
Fast55 is offline
post #5 of 11 Old 03-13-2019, 05:01 PM Thread Starter
Kaiser1983
So I took the car back to the dealership today. They took some air out of the tires and advised me about the lane assist. I lowered the sensitivity of it so I will see how that goes. Thank you all for the suggestions.
post #6 of 11 Old 03-13-2019, 05:14 PM
ColdCase
ColdCase's Avatar
2011 WK
Oh yeah, lane assist
ColdCase is offline
post #7 of 11 Old 03-13-2019, 06:16 PM
Fast55
Fast55's Avatar
2017 WK
There are actually a couple of different settings. You can adjust both the intensity of the correction feedback and sensitivity or early/late, of the warning. There is a noticeable difference between the settings.
2017 Trailhawk
Hemi
Rock Rails
Fast55 is offline
post #8 of 11 Old 03-14-2019, 07:50 PM
Roadijeff
Roadijeff's Avatar
33F, 36R. Look on the sticker on the door jam.
Roadijeff is offline
post #9 of 11 Old 03-16-2019, 06:55 AM
BigTizzie
BigTizzie's Avatar
2011 WK
Geez, lane assist? I was going to say check toe in on front tires. My jamb says 33 psi front and rear.
Self driving vehicle! All these bells and whistles.
https://www.jeep.com/cherokee/safety-security.html
BigTizzie is offline
post #10 of 11 Old 03-16-2019, 05:13 PM
Fast55
Fast55's Avatar
2017 WK
Jeep calls it laneSense. Between 37 and 112 MPH if the front camera can detect and "lock in" both sides of the lane, it will give you a bump back towards the center if you start to drift out of the lane unless you signal first. It actually works pretty good. I also have 33 PSI front and rear listed but a few more PSI in the front makes more sense.
2017 Trailhawk
Hemi
Rock Rails
Fast55 is offline
post #11 of 11 Old 03-17-2019, 09:38 AM Thread Starter
Kaiser1983
Thanks for the replies the tire sticker on my driver side actually says 36 in the front and 36 in the rear.
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 447 02-02-2019 10:42 PM
High Beam Dimmer problem OfficerMike TJ Wrangler Technical Forum 14 10-21-2018 08:25 PM
Turn signal turns on high beam problem Solano76 XJ Cherokee Technical Forum 2 01-17-2018 01:16 PM
Problem with upgraded headlight wiring harness ExJ XJ Cherokee Technical Forum 5 01-14-2018 08:08 AM
