2018 JGC Altitude Rims on a 2015 JGC Limited - JeepForum.com
 1Likes
  • 1 Post By alko
post #1 of 9 Old 03-16-2019, 09:25 AM Thread Starter
alko
Hello all, I need some help. I bought a complete set of wheels and tires that came off of a 2018 JGC Altitude and installed them on my 2015 JGC Limited. Apparently the sensors on the Altitude rims aren’t compatible with my vehicle. I drove the vehicle at least 60 miles. Anyone know if there are any issues with replacing the sensors with compatible ones? I called the Jeep dealership and the service advisor didn’t appear to know what I was talking about but he said that he wasn’t sure if they’d fit. Please let me know. Thanks in advance.
alko is offline
post #2 of 9 Old 03-16-2019, 09:28 AM
WindyCity
They changed the sensor in 16' I believe. All you need to do is get a set of the correct sensors for 11-15 and swap them in and should be good to go.
WindyCity is offline
post #3 of 9 Old 03-16-2019, 09:35 AM Thread Starter
alko
Thanks WindyCity. Yeah, so I found the below link where it stated that they changed them for the 2016. So there shouldn’t be any issues with fitment?
http://www.wk2jeeps.com/wk2_tpms.htm
alko is offline
post #4 of 9 Old 03-16-2019, 09:59 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
https://www.jeepforum.com/forum/f309...mmary-2798314/
No issues, the SRT wheels are a little different, but otherwise not a fitment issue. You should be able to get a set of four OEMs on ebay for less than $100 (the 2015 compatible part numbers are also listed at wk2jeeps). Or buy them from the tire shop, they probably would use programable ones which sometimes are flakey when used in a WK2.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #5 of 9 Old 03-16-2019, 07:00 PM Thread Starter
alko
Thanks ColdCase, I appreciate it. I was going to go the route of buying Mopar sensors and having them installed at my local Goodyear shop, however they don't install customer parts at all (called multiple shops to confirm). They wanted $145 per tire which included installing their aftermarket sensor, balance, and reprogram. I think this may be my best bet, as there aren't too many tire shops I trust around here. I'll get another quote from another dealer as well. Thanks again!
alko is offline
post #6 of 9 Old 03-16-2019, 07:58 PM
WindyCity
Don't know your location, but try and find a small tire shop they should have no problem installing your parts. That seems like a lot of money when sensors can be found for pretty cheap on ebay,etc...
post #7 of 9 Old 03-16-2019, 08:22 PM
ColdCase
ColdCase's Avatar
2011 WK
Small shops here charge maybe $20 per tire if you provide the sensors. There are some shop chains that sell expensive $125 sensors, however. You can always just drive without the sensors and old school check tire pressure now and then. Are you still using the other wheels? If not you could try swapping sensors, but the shop may say they are too easy to break.
The Jeep will not need to be programed as it automatically detects new sensors.
ColdCase is offline
post #8 of 9 Old 03-16-2019, 08:23 PM
BigTizzie
BigTizzie's Avatar
2011 WK
My 2005 TPMS didn't work in my 2011. They have a differing MHz signal. 315 vs 433.
I have some new SRT knockoffs going on the front this week. Discount Tire will put my sensors in, I think. I actually did already. You can DIY, just need that tool and some dish soap to pull them in.
https://www.rockauto.com/en/moreinfo...446514&jsn=395
BigTizzie is offline
post #9 of 9 Old 03-18-2019, 10:49 AM Thread Starter
alko
Thanks for the replies you guys, I appreciate it! I think I may buy the mopar sensors and take them to another shop. $145 per tire is a ton of money considering I only paid $400 for rims and tires. The tires only have circa 10k miles on them. Or trying to drop another $500 or so just to install sensors. Now to find some mopar sensors for the low. Thanks again everyone!
BigTizzie likes this.
alko is offline
Traded my 2015 for a 2018 yesterday. JGC Ecodiesel. Tafcrcr WK2 Grand Cherokee Forum 7 12-21-2018 03:31 PM
New 2015 JGC Limited jopina7800 WK2 Grand Cherokee Forum 3 10-25-2018 02:26 AM
Service and repair manuals for 2018 JGC Limited andyo5 WK2 Grand Cherokee Forum 12 10-04-2018 08:01 AM
2019 Cherokee Limited to 2018 GC Altitude Scottykenneth WK2 Grand Cherokee Forum 2 07-17-2018 09:03 AM
YJOTM Archive - Apr 2019 - Enter Now jbolty YJ Wrangler Technical Forum 7 01-11-2017 08:04 AM
