2018 GCL Nav brightness - JeepForum.com
post #1 of 6 Old 07-22-2021, 04:08 PM Thread Starter
frank1969
I'm sure someone has an answer for this. My Nav is too bright at night. The "Display Brightness with headlights on or off "are both grayed out. Any help would be appreciated! 2018 Grand Cherokee Limited Thanks!
frank1969 is offline
post #2 of 6 Old 07-22-2021, 07:34 PM
ottoman89
I have the same issue with my '12. I have Auto Brightness on and it doesn't change.
ottoman89 is offline
post #3 of 6 Old 07-22-2021, 08:23 PM
Roadijeff
Roadijeff's Avatar
The Display Brightness will be greyed out if the line above it is set to Auto. Check the Manual box and you should be able to adjust it. I also have a 2018 GC and mine is set in Auto mode but the nav is not too bright at night on it.
Roadijeff is offline
post #4 of 6 Old 07-23-2021, 06:17 AM
WK2Overland4X4
Have you tried the dash dimmer knob by the headlight switch? It might be clicked all the way up to Parade Mode.
2021 Summit L 4X4 Bright White/Steel Gray, 3.6 , ProTech IV, Lux Tech V.
WK2Overland4X4 is offline
post #5 of 6 Old 07-23-2021, 07:44 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
After review of your Owner's Manual, I found this information on page 185 regarding "Interior Lights":
The brightness of the instrument panel lighting can be regulated by rotating the dimmer control up (brighter) or down (dimmer). When the headlights are on you can supplement the brightness of the odometer, trip odometer, radio and overhead console by rotating the control to its farthest position up until you hear a click. This feature is termed the “Parade” mode and is useful when
headlights are required during the day."
We recommend reviewing the manual for assistance!
Kate
Jeep Cares
Hi, frank1969. I pulled up the Owner's Manual for your Grand Cherokee as well and found this information on page 514:
"Display
After pressing the “Display” button on the touchscreen, the following settings will be available:
Display Brightness With
Headlights On
To make changes to the Display Brightness with Headlights ON setting, the headlights must be on and the interior dimmer switch must not be in the party or parade positions."
We recommend checking that page out as it does have a table that I am unable to copy/paste here and it may be helpful.
Kate
Jeep Cares
JeepCares is online now
post #6 of 6 Old 07-23-2021, 08:58 AM
BubbaATL
2018 WK
Turn Auto brightness off AND then set brightness with headlights off while they are off, then turn them on to set the brightness with headlights on.
The problem I've had is I can't get it to remember those settings, even if I re-memorize my Driver 1 and 2 settings.
2018 Limited 3.6L with pretty much everything ("almost a Trailhawk")
BubbaATL is offline
