2017 wonít move after axel replacement - JeepForum.com
 8Likes
post #1 of 21 Old 10-20-2021, 08:24 PM Thread Starter
Rhudene
Rhudene's Avatar
Iíve recently replaced the passenger side axel after it was damaged in a collision,
the jeep moved before I changed the axel even while being damaged from the collision , Iíve made sure the axel shaft was pushed all the way in , and the vehicle does now is rev , when placed back in park the dash reads vehicle speed to high to shift to park
Rhudene is offline
post #2 of 21 Old 10-20-2021, 10:09 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
With both tires off the ground, does one or both wheels turn too freely? Does the driveshaft spin when in drive with both wheels on the ground?
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 21 Old 10-20-2021, 10:43 PM Thread Starter
Rhudene
Rhudene's Avatar
Yes
Rhudene is offline
post #4 of 21 Old 10-20-2021, 10:45 PM Thread Starter
Rhudene
Rhudene's Avatar
Yes
Rhudene is offline
post #5 of 21 Old 10-20-2021, 11:31 PM
ColdCase
ColdCase's Avatar
2011 WK
Are you still unable to shift to park?
ColdCase is offline
post #6 of 21 Old 10-21-2021, 12:42 AM Thread Starter
Rhudene
Rhudene's Avatar
Yes I can shift to park after shifting to neutral and waiting for the drivetrain to stop spinning Öany attempt to shift to park prior to that just leads to the ďvehicle is still moving unable to park messageĒ
Rhudene is offline
post #7 of 21 Old 10-21-2021, 06:48 AM
RedTrex
2014 WK
Sounds like the replacement axle did not engage the spider gear. Did you by chance move the diff internals with the old axle out by moving the opposite wheel and/or the driveshaft?
- Only way to fix at this point will be to open pig up and see what happened. Probably pull that new axle out slightly and re-install
2003 Libby 2x4 (Gone)
2004 Libby 4x4 (Gone)
2013 Wrangler JKU (Gone)
2014 WK2 Ecodiesel (485 tq)
RedTrex is offline
post #8 of 21 Old 10-21-2021, 08:10 AM Thread Starter
Rhudene
Rhudene's Avatar
Yeah I ran the Jeep into my driveway with the old axle detached
Rhudene is offline
post #9 of 21 Old 10-21-2021, 08:23 AM Thread Starter
Rhudene
Rhudene's Avatar
Rolled
Rhudene is offline
post #10 of 21 Old 10-21-2021, 08:23 AM
ColdCase
ColdCase's Avatar
2011 WK
Yeah with it in park and one wheel on the ground, you shouldn't be able to spin the one off the ground. Something let loose in the diff or the axle is wrong for the jeep. Do you know which diff you have (195, 230) ? They do have different half shaft part numbers, one is shorter I think.
The only caustion I see in the manual is to be careful to not damage the Diff seals.
ColdCase is offline
post #11 of 21 Old 10-21-2021, 09:13 AM Thread Starter
Rhudene
Rhudene's Avatar
Iím not sure which differential I have the only thing Iím certain of is that itís an single speed transfer case Ö Iíll pull the diff specs with my launch scan tool
Rhudene is offline
post #12 of 21 Old 10-21-2021, 11:18 AM Thread Starter
Rhudene
Rhudene's Avatar
Rhudene is offline
post #13 of 21 Old 10-21-2021, 04:51 PM
scott_0
scott_0's Avatar
sounds as if the axle is not inserted all the way into the diff, as suggested a few posts back. I've had it happen before, there is a small ring that makes for an interference type fit, if it's not slid past the internal notches, the vehicle won't move. You have push with a little bit of quick force to get that clip to engage.
2018 GC Limited
scott_0 is offline
post #14 of 21 Old 10-26-2021, 08:22 AM
scott_0
scott_0's Avatar
sooooooo OP, did you ever figure this out???
2018 GC Limited
scott_0 is offline
post #15 of 21 Old 10-26-2021, 10:00 AM Thread Starter
Rhudene
Rhudene's Avatar
I haven't had the time to get back around to it , been working on other project cars , might check the axle today I will keep you posted.
scott_0 likes this.
Rhudene is offline
