2017 Trailhawk problems - JeepForum.com
 1Likes
  • 1 Post By ColdCase
post #1 of 12 Old 02-14-2020, 09:16 PM Thread Starter
98BlackZJ
98BlackZJ's Avatar
A couple months back (November 21st) I got the bright idea to trade in my trouble free 2015 WRX on this certified preowned 2017 Trailhawk w/ 44k miles. The first 2 months, 2500ish miles went great, then, on my way to work the ABS, stability control, and service 4WD lights came on. I take it to the dealer(different dealer than where I bought it from), they tell me it needs a rear wheel bearing at a cost of $785, not covered by warranty.
After several phone calls, as far as I can tell, the dealer I bought it from never entered the 3 month/3000 mile warranty into the computer, I've contacted them and they claim everything is correct on their end. I've contacted Chrysler warranty, mopar vehicle protection, Chrysler certified preowned, and jeep customer service and no one seems able to help.
Not about to spend another $800 (on top of the $600 I've already spent on diagnostic and rental car fees) I install a new wheel bearing and a new ABS sensor and the lights are still on.
Honestly at my wits end with this thing and about ready to trade it in on something else
98' 5.2 ltd, 4.5" lift, 33x12.50 KM2's, Clayton's longarms, 8.8/HP30 Aussie F&R
98BlackZJ is online now
post #2 of 12 Old 02-14-2020, 09:52 PM
elJeepo_00WJ
2011 WK
Do you not have any factory warranty remaining? Isn't the powertraing 3yr/60k miles? Has the dealer you purchased from offered to diagnose the vehicle and cover the issues under that original warranty?
why is my jeep always breaking???
elJeepo_00WJ is offline
post #3 of 12 Old 02-14-2020, 10:29 PM
ceb1
ceb1's Avatar
Contact JeepCares here via PM. They should be able to help.
ceb1 is offline
post #4 of 12 Old 02-15-2020, 12:42 AM
2008OverlandCRD
2017 WK
Buy the max care extended warranty.
Certified pre-owned ones only come with a 3 month warranty?
Shouldn’t it be covered under the powertrain warranty?
Nevermind, found it:
Jeep's certified pre-owned (CPO) program offers two main benefits: a 3-month or 3,000-mile bumper-to-bumper warranty that starts at the end-of-factory bumper-to-bumper coverage and a 2-year extension on the factory powertrain warranty that brings the total powertrain-coverage figure to 7 years or 100,000 miles.
Powertrain warranty:
All Wheel Drive (AWD):
power transfer unit and all internal parts; viscous cou- pler; axle housing and all internal parts; constant velocity joints and boots; driveshaft and axle shaft assemblies; differential carrier assembly and all internal parts; output ball bearing; output flange; end cover; overrunning clutch; vacuum motor; torque tube; pinion spacer and shim, seals and gaskets for listed components only.
Rear Wheel Drive:
rear axle housing and all internal parts; axle shafts; axle shaft bearings; drive shaft assemblies; drive shaft center bearings; universal joints and yokes; seals and gaskets for listed components only.
2017 Jeep Grand Cherokee Summit 4x4, 5.7 Hemi, platinum pkg, ivory 3-coat, skid plates.
2008OverlandCRD is offline
post #5 of 12 Old 02-15-2020, 07:11 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The powertrain warranty does not cover wheel bearings, does cover the half shafts. I've had to do both on my KK.
Do you have the codes? A wheel sensor, steering angle sensor, speed sensor, brake switch, bad connection, tone wheel, ABS module, low battery can all cause those lights.The wheel bearing may have been bad, but its not going to cause that code unless the tone wheel was affected.
I was born with nuttin' and I still have most of it
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #6 of 12 Old 02-15-2020, 11:17 AM
jtpeters
Perhaps my Lifetime Max Care Warranty is different from the Factory Powertrain warranty.
My warranty states:
FOUR-WHEEL DRIVE (4x4): Transfer Case and all Internal Parts; Axle Housing and all Internal Parts; Axles Shafts; Axle Shaft Bearings; Drive Shafts Assemblies (Front and Rear); Drive Shaft Center Bearings; Wheel Bearings; Universal Joints and Yokes; Disconnect Housing Assembly; Seals and Gaskets.
2004 Jeep Overland WJ 4.7 H.O. (Bought new in Oct 2003)
2014 Jeep Overland WK2 5.7 Hemi (Bought used in 2016 w/7k miles)
1970 Ford Mustang Boss 302 (in Family since 1974)
2013 Ford Mustang Boss 302
2011 BMW 328i
jtpeters is offline
post #7 of 12 Old 02-15-2020, 01:43 PM
ColdCase
ColdCase's Avatar
2011 WK
Yes, MaxCare goes beyond the Factory Powertrain type warranty mentioned as part of the certified pre-owned deal. MaxCare is similar to the Factory bumper to bumper warranty.
post #8 of 12 Old 02-15-2020, 01:47 PM
Homer1
Homer1's Avatar
I love jeeps; i hate their service...both mechanical and customer. Despite what your extended contract states, they can and will find other reasons why not to cover them. I'm in the middle of a contract dispute myself, but I'm not giving up on my 3rd of 4 jeeps. Don't give up.
2017 GC Trailhawk
2008 GC Limited
2014 Acura RDX
1997 GC Limited Beach Buggy (Deceased....RIP)
Homer1 is offline
post #9 of 12 Old 02-15-2020, 07:29 PM Thread Starter
98BlackZJ
98BlackZJ's Avatar
When I put in my information on the MVP website, the 7 year/100,000 mile powertrain warranty is listed, but the 3 month/3,000 mile warranty is not. Wheel bearings are listed under the 4WD/AWD section as being covered, however, what I was told by 2 different dealerships is that only front wheel bearings are covered, rear are not.
The codes listed on the paperwork from the dealer are U1412-00, and C003A-1D
post #10 of 12 Old 02-16-2020, 07:08 AM
ColdCase
ColdCase's Avatar
2011 WK
Dealers simply plug in the repair codes and the FCA computer tells them if the repair is covered by a warranty. If they think somethings not right they contact FCA. If you think somethings not right, there is customer assistance, member jeepcares here or call/email them, contact info on jeep.com.
post #11 of 12 Old 02-16-2020, 04:38 PM
ColdCase
ColdCase's Avatar
2011 WK
C003A-1D is Right Rear Wheel sensor current out of range. This gets set when the sensor fails the diagnostic test..
CONNECTOR/TERMINAL DAMAGE
(B1) RIGHT REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT SHORTED TO VOLTAGE
(B2) RIGHT REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT SHORTED TO VOLTAGE
(B1) RIGHT REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT SHORTED TO GROUND
(B2) RIGHT REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT SHORTED TO GROUND
(B1) RIGHT REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT OPEN
(B2) RIGHT REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT OPEN
(B2) RIGHT REAR WHEEL SPEED SENSOR SUPPLY CIRCUIT SHORTED TO THE (B1) RIGHT REAR WHEEL SPEED SENSOR SIGNAL CIRCUIT
ANTI-LOCK BRAKE SYSTEM (ABS) MODULE
Ui412-00 is an implausible vehicle speed signal received from the ABS module by the PCM (invalid message or not received as expected)
CAN C BUS OPEN OR SHORTED CONDITION
NO POWER TO ANTI-LOCK BRAKE MODULE - MODULE UNPLUGGED OR OPEN FUSE
POWERTRAIN CONTROL MODULE (PCM)
That usually adds up to an PCM module failure, but could be the ABS module or a bad connection or low battery.
There are other ABS faults that could result from a bad bearing, but not likely these.
After DTC reset, sometimes you have to do several minutes of driving above 10mph for the fault light to clear.
This is a 2011 diagram, the 2017 is probably similar.
ceb1 likes this.
post #12 of 12 Old 02-17-2020, 08:58 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hi 98BlackZJ,
Thank you for reaching out here, I can certainly understand why this may be frustrating. Please send us a private message with your VIN so that we may look into this further for you.
Kathryn
JeepCares
JeepCares is online now
