2014 Jeep WK2 Limited - JeepForum.com
post #1 of 15 Old 01-20-2018, 09:06 PM Thread Starter
bucks09wk
2009 WK
Hi,
I just purchased a 2014 WK2 Limited.
I have a couple questions:
1) The license plate bulbs are burned out? How could this happen? Aren't LEDs supposed to last super long?
2) The center console hinge is disconnected? How do I fix that?
Thanks,
Christian
bucks09wk is offline
post #2 of 15 Old 01-20-2018, 09:36 PM
C0mbatChris
C0mbatChris's Avatar
2014 WK
I would take it back to the dealership you purchased it from and ask them to make the repairs. At minimum the center console, I think the license plate lights will be an easy fix..
{ 2014 Grand Cherokee 5.7L V8 Limited QTII }
{ 2017 Cherokee 2.4L 4cyl Limited <Wife's }
C0mbatChris is offline
post #3 of 15 Old 01-20-2018, 10:00 PM Thread Starter
bucks09wk
2009 WK
Is the Led Lamp an easy fix? How much does it cost?
post #4 of 15 Old 01-20-2018, 11:50 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I don't think the LED license bulbs are socketed. You may have to buy the entire appliqué at about $200. I would look for a bad connection, or think about having the place you purchased repair it.
You may also have to replace the entire console to fix the lid.
Some people think I'm stupid and I totally disagree. But my biggest fear is that me thinking I'm smart proves them right.....
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #5 of 15 Old 01-21-2018, 02:15 PM
C0mbatChris
2014 WK
Easy fix, not cheap... kit is 68360247AA and will cost about $110. Dealer will charge close to $200 to do it.
post #6 of 15 Old 01-21-2018, 02:32 PM
ColdCase
ColdCase's Avatar
2011 WK
Oh yeah, the so called wire harness that comes with the LEDs, not the appliqué.
https://parts.moparonlineparts.com/o...PWxheWVyXzM%3D
ColdCase is offline
post #7 of 15 Old 01-21-2018, 02:55 PM Thread Starter
bucks09wk
2009 WK
The right license plate bulb has brown around the circuit. The left one looks fine.
2014 Jeep Grand Cherokee Limited 5.7 (Cathy)
post #8 of 15 Old 01-21-2018, 02:59 PM Thread Starter
bucks09wk
2009 WK
I don't understand the harness issue. Why can't I just purchase the bulbs themselves?
Is there a part number for the bulbs not for the entire harness.
post #9 of 15 Old 01-21-2018, 03:11 PM
ColdCase
ColdCase's Avatar
2011 WK
As mentioned before, the LEDs themselves are not individually socketed, they are soldered to the wires in the harness.The little harness has a plug that plugs into the body harness. If you are handy, you may be able to remove the LEDs and solder new ones onto the wires, if you can find equivalents.
ColdCase is offline
post #10 of 15 Old 01-21-2018, 08:46 PM Thread Starter
bucks09wk
2009 WK
How do I know if the harness is bad? The right led has a burn mark but the left one doesn't. Is there a place where I can just buy the two led assemblies not the harness. I took it out and seems like you can unplug the assembly.
post #11 of 15 Old 01-21-2018, 10:14 PM
ColdCase
ColdCase's Avatar
2011 WK
Jeep probably calls the part you call an assembly, a wire harness, not cheap. Check the diagram in the moparpartsonline link above and compare the diagram with your assembly.
ColdCase is offline
post #12 of 15 Old 01-22-2018, 09:30 AM Thread Starter
bucks09wk
2009 WK
If I somehow get the bulbs, will the LEDs blow instantly when I plug them in?
post #13 of 15 Old 01-22-2018, 12:21 PM Thread Starter
bucks09wk
2009 WK
Also, does anyone have instructions on how to replace the wiring harness?
post #14 of 15 Old 01-22-2018, 12:58 PM
ecupip
$84 on ebay. No tax and free ship.
https://www.ebay.com/itm/Jeep-CHRYSL...BZNWeu&vxp=mtr
Current: 2011 GC Limited Dark Charcoal, Lux II, Off Road, HEMI.
ecupip is offline
post #15 of 15 Old 07-26-2019, 09:54 PM
Raptor
These will work, exact OEM replacement parts;
For a 2013-2018 Fiat 500. And also Jeep Grand Cherokees!
68228931AA
68228930AA
https://www.ebay.com/itm/2013-2018-F...oAAOSwj2Za4bCI
Read about it here;
https://www.jeepforum.com/forum/f309...89/index2.html
Raptor is offline
interior , jeep , led , wk2
