2013 Loredo 4x4, Transfer Case problem - JeepForum.com
post #1 of 5 Old 07-07-2020, 02:13 PM Thread Starter
ginnmt
Hey all, my 2013 Loredo 4x4 is making a loud click/thunk repeatedly, upon acceleration, especially on an incline or given heavy gas. It runs fantastically once up to speed, but I really have to baby it to get it there, and in TN, hill starts are nearly impossible to avoid. I've had it looked at, and ruled out axles, diff, and drive shaft, was told the transfer case would need to be replaced. Hooray. Part new is nearly 2 grand, and a rebuilt one is still over $1000. So before I bite the bullet, I thought I'd check with you lovely people to see if you had and other ideas or something I may be overlooking. Or if anyone knows of anywhere that might sell the part a little cheaper? I don't have high hopes or expectations, but it's worth a shot! Thanks, y'all!
ginnmt is offline
post #2 of 5 Old 07-07-2020, 02:47 PM
WK2Overland4X4
2012 WK
Who told you the transfer case was the problem, and how did they determine that? If it was just a guess, check all driveshafts for play. And have someone outside the car listening as you pull out to help locate the source, or someone riding in the back as well.
WK2Overland4X4 is offline
post #3 of 5 Old 07-07-2020, 03:16 PM
emacca
Have you changed the oil??
Cheap easy job to do
emacca is online now
post #4 of 5 Old 07-07-2020, 04:53 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Did you have the motor mounts checked? It sounds like a classic motor mount problem. Or perhaps one of the suspension bushings. There are a couple threads indexed in the maintenance sticky.
On the other hand, if the transfercase chain sprockets are worn enough, they will jump teeth with a thunk. Thats usually where techs migrate to, if they aren't aware of the common motor mount wear issue.
Next they may suspect the transmission as sticky/worn clutches can slip under acceleration with a thunk. So have the tranny fluid level checked.
Some people think I'm stupid and I totally disagree. But my biggest fear is that me thinking I'm smart proves them right.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #5 of 5 Old 07-13-2020, 04:22 AM
SENECA
SENECA's Avatar
I have a 2012 4X4 and it was doing the same thing. I drained and replaced the fluid in the transfer case and it fixed the problem.
"The Wheel In the Sky Keeps on Turning"
SENECA is offline
