2012 Grand Cherokee Issues - JeepForum.com
post #1 of 3 Old 05-24-2019, 07:32 PM Thread Starter
ChuckCastiglion
Our 2012 GC has had starter push button issues since last year. We have to push the button 3 separate times before the starter will crank and then the car starts perfectly. If you pop the start button out and use the key/fob in the hole, it starts perfectly. If you use the remote start it works perfectly. I posted this same issue last year. There are also some other issues that I believe are related. The cruise control dash indicator will not come on and therefore doesn't work. And the radio will remain "ON" for a while after the car is turned "OFF' and the door is opened. The brake light switch seems to work fine. Anyone have any thoughts? Thanks in advance! Happy Memorial weekend!:
ChuckCastiglion is offline
post #2 of 3 Old 05-25-2019, 08:51 AM
woodsy18
Have you replaced the fob batteries yet? My 12 seems to have starting issues around the same time as the battery goes out in the fob
Sent from my SM-G950U using Tapatalk
woodsy18 is offline
post #3 of 3 Old 05-25-2019, 11:05 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Sure sounds like a FOB, PEM, or PEM antenna issue, there are four of them running under the carpets. I forget if you need to have a foot on the brake to start with the button popped out, but if not, the brake switch could be intermittent. Its like a three contact switch, the brake lights being on a separate contact. There was a tread here awhile ago where a member replaced the brake switch and all was well. Did the dealer replace the brake switch or check the PEM antennas? Was the PEM ever replaced? Do both FOBs act the same?
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
2012 JK introduction and transfer case issues? Zah722 JK Wrangler 0 02-19-2019 10:12 PM
Electrical/Engine Issues with 2015 Wrangler jb1378 JK Wrangler Technical Forum 4 09-23-2018 01:06 AM
2017 Renegade Lemon Law Process due to many issues. 4x4inmyjeep Jeep BU Renegade & MP Compass Forum 4 09-19-2018 06:51 PM
2012 Laredo radio issues Stochmal52 WK2 Grand Cherokee Forum 2 08-10-2018 03:48 PM
