2011 grand cherokee rack and pinion - JeepForum.com
post #1 of 2 Old 05-24-2020, 08:42 AM Thread Starter
2011jeepGrand
Saw my rack and pinion was leaking so I went to replace it but now we can't get it out. We've removed both axles and all 3 bolts mounting the front diff and there's still no room ro remove the old rack. Any suggestions?
2011jeepGrand is offline
post #2 of 2 Old 05-25-2020, 07:10 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
On a V6:
Lift and rotate the steering gear so that the steering shaft is forward to clear the oil pan when removing the steering gear through the RH wheel area.
Lift and rotate the steering gear as necessary to remove from behind the knuckle/rotor assembly of the RH wheel area.
On a V8 you probably need to drop the engine cradle crossmember.
I was born with nuttin' and I still have most of it
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
