2011 GC WK2 rear drive shaft - JeepForum.com
 3Likes
post #1 of 26 Old 11-21-2018, 12:35 PM Thread Starter
osd4x4
The rear rubber flex joint of the drive shaft has torn it self apart. Unfortunately the part doesn't appear to be available and Jeep sell the whole drive shaft. Currently the dealer is saying the drive shaft isn't available until Dec 6th at the earliest (some kind of manufacturing problem).
My question is has any body found the rubber flex joint available seperately?
osd4x4 is offline
post #2 of 26 Old 11-21-2018, 12:48 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I haven't found the joint separate, but there seems to be dealers that have the shaft in stock, if thats an option for you. Rockauto and moparonlineparts.com for example.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 26 Old 11-21-2018, 12:58 PM Thread Starter
osd4x4
Thanks, yeah both rockauto and mopar show the parts but when you check out they are on back order. I've found one I've ordered out of Florida. I'm looking for a quicker delivery option.
osd4x4 is offline
post #4 of 26 Old 11-21-2018, 01:23 PM
ColdCase
ColdCase's Avatar
2011 WK
Yeah, I hate when that happens. Sometimes they are pretty good about showing in stock status, sometimes you get an email days later.
osd4x4 likes this.
ColdCase is offline
post #5 of 26 Old 11-21-2018, 04:48 PM
bobabraham6
2013 WK
You might try your local driveshaft shop and see if they can rebuild yours
Sent from my iPhone using Tapatalk
bobabraham6 is offline
post #6 of 26 Old 11-21-2018, 10:53 PM
Kolak
Vendor
Kolak's Avatar
Which engine do you have in your WK2?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #7 of 26 Old 11-24-2018, 07:10 PM
Gtodog69
I've been looking around and found a guy that used a coupler for a Mercedes. The drivetrain on the Jeep is mostly German. Powertrain Industries GAD01-010. Says it fits perfectly. Been about 10,000 miles since it was done.
Gtodog69 is offline
post #8 of 26 Old 11-25-2018, 05:13 PM Thread Starter
osd4x4
Thanks, thats a great help.
osd4x4 is offline
post #9 of 26 Old 11-28-2018, 02:24 PM Thread Starter
osd4x4
Unfortunately it was not the correct part, it has 6 bolt holes not 8
osd4x4 is offline
post #10 of 26 Old 11-29-2018, 11:23 AM
Gtodog69
I've looked up the factory drive shaft with the coupler on it. This is the pic I have of it. OEM number is 52853646AE. It has 6 holes. Can you post a picture of yours?
Gtodog69 is offline
post #11 of 26 Old 11-29-2018, 11:50 AM
ColdCase
ColdCase's Avatar
2011 WK
I think the smaller rear diffs used in the V6 have a three hole flange (6 hole flex disk), larger ones used in the V8 and diesel have a four hole flange (8 hole flex disk). Thats probably why Kolak was asking which engine the OP had.
3hole: 195RIA, 215RII
4hole: 225RII, 230RIA
Sounds like he has the larger diff.
Powertrain Industries GAD01-010 has 6 holes and may fit the smaller diff. Dunno if there is a Merc model that uses the larger Dif.
ColdCase is offline
post #12 of 26 Old 11-29-2018, 12:15 PM
ColdCase
ColdCase's Avatar
2011 WK
Their catalog is here: https://www.powertrainindustries.com...ber+Flex+Discs
Looks like the GAD01-017, for example, has the same dimensions as the GAD01-010 and it has 8 holes. So if the GAD01-010 seems to fit except for number of holes, the -017 may work.
https://www.powertrainindustries.com...&make=Mercedes
BigTizzie likes this.
ColdCase is offline
post #13 of 26 Old 11-29-2018, 01:20 PM
Kolak
Vendor
Kolak's Avatar
Assuming that's the correct part number, I do see that driveshaft as being available.
or
Kolak is offline
post #14 of 26 Old 11-29-2018, 01:32 PM
Gtodog69
Their catalog is here: http://www.powertrainindustries.com/...ber+Flex+Discs
http://www.powertrainindustries.com/...&make=Mercedes
I didn't realize there were different diffs. Thanks for the heads up. I'll have to crawl under mine and look. I've got an Overland with a Hemi.
Gtodog69 is offline
post #15 of 26 Old 12-11-2018, 07:32 AM Thread Starter
osd4x4
Update,
First off thanks for all the usefull information.
The first coupler I found was the wrong one (6 bolt).
I found the correct part (8 bolt) part number SGR GAD 01-005-Z.
Unortunately for me after aremoval of the drive shaft there damage done by the failing coupler. So I do need a new drive shaft. The availablility date has now pushed back to the 20th I'm told there are 1000 jeep owners currently in the same position.
osd4x4 is offline
