2011 5.7 limp mode(only 4th gear) with fans in high speed - JeepForum.com
 2Likes
  • 1 Post By ColdCase
post #1 of 3 Old 07-22-2021, 01:13 AM Thread Starter
janusz123
Hi, I am owner of Jeep Grand Cherokee 2011 5.7 Limited 4x4. I am dealing with one issue: when i turn it on, Jeep sometimes starts in limp mode( only 4th gear) but sometimes it is everything ok and drives perfectly until i turn it off and turn on again (no difference if engine is hot or cold, it just sometimes happened, sometimes it is ok few times in row ,sometimes will start with limp mode multiple times).
When jeep is on limp mode also fans are turning on in high speed and I noticed that transmission temperature on jeep computer shows nothing ( when turning on without limp mode temperature shows correct value).I don’t know what causes the problem and how to fixed it, , diagnostic tool shows code P0883,
I will be grateful for any help and advices.
janusz123 is offline
post #2 of 3 Old 07-22-2021, 06:48 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
On the V8 of that era the Transmission Control is built into the PCM. This DTC is set if the Powertrain Control Module (PCM) senses greater than 3.0 volts on the Transmission Control Relay Output circuits prior to a request from the PCM to energize the Transmission Control Relay.
The Transmission Control Relay is used to supply power (Transmission Control Output) to the Transmission Solenoid/TRS Assembly when in normal operating mode and to pins C4-19, C4-28 and C4-38 of the PCM. The purpose of the Transmission Control Relay is to allow the Powertrain Control Module (PCM) to turn off the power to the Transmission Solenoid/TRS Assembly in event that the transmission should need to be placed into “limp-in” mode due to a DTC.
After a PCM reset, (ignition switch turned to the run position, or after cranking engine) the PCM verifies that the Transmission Control Relay contacts are open by checking for voltage on the Transmission Control Relay Output circuit before the Transmission Control Relay is energized. If voltage is detected, the DTC will set.
Possible causes:
(T15) TRANSMISSION CONTROL CIRCUIT SHORTED TO VOLTAGE
(T16) TRANSMISSION CONTROL OUTPUT CIRCUIT SHORTED VOLTAGE
TRANSMISSION CONTROL RELAY
TRANSMISSION SOLENOID/TRS ASSEMBLY
POWERTRAIN CONTROL MODULE (PCM)
Sounds like an intermittent, but the first thing I'd do do is replace the relay. If that doesn't fix, you are going to have to troubleshoot the harness and then perhaps replace the PCM.
SKALA308 likes this.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #3 of 3 Old 07-22-2021, 06:55 AM
ColdCase
ColdCase's Avatar
2011 WK
I think, off hand, that the relay is in the TIPM and labeled PCM, K5 on the following diagram.
