14-16 Heated seat / steering wheel swap? - JeepForum.com
post #1 of 3 Old 05-28-2020, 08:09 PM Thread Starter
darcym12345
Question 14-16 Heated seat / steering wheel swap?
Just wondering if anyone out there has accomplished a heated seat swap on a 14-16 Laredo? How about a heated steering wheel swap? I'm keen on the seats (but don't need the steering wheel) option but can't find one with low KM!
Thanks!
darcym12345 is offline
post #2 of 3 Old 05-28-2020, 10:41 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
If you want OEM, there are the seats, wire harness, a couple control modules (a couple may come with the new seat, a switch panel, and some software configuration changes. If you don't care about OEM function, install the seats and wire up the heater circuits to a power supply (or put a heating pad in your seat cushions. . Someone here put SRT seats in a Laredo awhile ago, when I get back I'll try to find the thread.
I was born with nuttin' and I still have most of it
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 3 Old 06-01-2020, 09:32 PM
ceb1
ceb1's Avatar
You need to be a bit careful here. Did the airbag systems change between years and models? Even if the plugs are the same, that is no guarantee that the airbags will function as intended.
Remember that the manufacturer tests each model and engine combination.
ceb1 is offline
