Unibody rust, the never ending battle - Page 11 - JeepForum.com
 1Likes
post #151 of 162 Old 09-09-2019, 01:36 PM
Chereveco
2008 KK Liberty
Originally Posted by Rob K View Post
Sprayed fluid film in the cross members and such. Front is done. Will start on the back brakes in a week or so.
Good luck with it!!
Sent from my SNE-LX3 using Tapatalk
Neil Cordoba de Jongh
Costa Rica
Chereveco is offline
post #152 of 162 Old 09-09-2019, 08:33 PM Thread Starter
Rob K
1995 XJ Cherokee
Thanks, but my luck has already run out. lol I thought the front was done, but the bearing is a little noisy now after using the slide hammer on the hub. The bearing grease might have cooked when the caliper seized also. I rotated wheels and swapped the rotors/pads from one side to the other and still getting a little rumble from the front passenger side. Had to order a new hub.
Rob K is offline
post #153 of 162 Old 09-20-2019, 07:24 PM Thread Starter
Rob K
1995 XJ Cherokee
Rear brakes done. That should get me by for several more years until things are closer to being worn out and in need of replacement. When that time comes everything will get painted before install so the parts will live a long life and wear out instead of being killed by rust.
With the rear brakes I sprayed on 4 heavy coats of the VHT Caliper paint. A lot more than they recommend on the can. Paint seems a good deal more durable and I believe it could use several more coats. I think next time I'll look for a brush on paint that I can lay on thicker for a more durable coat. Sandblasting is going to be a better option also. I guess the new parts would need sandblasting also if I'm going to put a good coat of paint on them before install. Would be nice if you could buy them already done.
Rob K is offline
post #154 of 162 Old 09-20-2019, 07:30 PM Thread Starter
Rob K
1995 XJ Cherokee
Next year will be driveshafts, gas tank skid, oil pans and stuff like that. And probably some more touch up.
Rob K is offline
post #155 of 162 Old 09-22-2019, 11:38 AM
Chereveco
2008 KK Liberty
It looks like my KK when I did the major maintenance three years ago...
Paint before installing is wise.
Painted removable parts are all brand new... Including the transmission support...
Costa Rica
post #156 of 162 Old 09-22-2019, 06:41 PM Thread Starter
Rob K
1995 XJ Cherokee
Next time I'm going to copy you and paint the drivetrain a light color. So did you scuff the paint before spraying? How's it holding up? I feel like I've spent a stupid number of hours under the Jeep cleaning, sanding and painting.
I was talking to my neighbor that has worked in auto parts his whole life. He said to by the premium brake parts since they are coated very well these days and should last a long while. He also has been to paint school for his job. They tested POR15 and Chassis Saver and found them to have similar performance.
Rob K is offline
post #157 of 162 Old 09-23-2019, 08:59 AM
Chereveco
2008 KK Liberty
Hi, Rob
I took the Jeep to a Sandblasting facility, so they removed all visible oxide, then a clean up with high pressure air, then applied a coat of "high holding" Premier, allowed to dry like for 3 hours, then the product in the can "Corrostop", wich is supposed to be the best one down here in Costa Rica.
Then, couple of weeks later took the Libby to a car wash where they pressure washed all the possible holes in the "chassis", After a couple of days with all dried up applied the other "Corrostop" product, the one in the galon, it is supposed to kill corrosion by converting back oxide back to metal, like giving back to the metal the molecules that are lost by corrosion... Oxide changes color dark blue...
So far, three years later it still looks fine, just little corrosion stains coming out from the seams or places where the metal sheets join...
Perhaps next year I'll do a retouching, both into the holes and metal sheets joints...
At the moment, no peeling or paint fall off...
Costa Rica
post #158 of 162 Old 09-23-2019, 03:57 PM Thread Starter
Rob K
1995 XJ Cherokee
I've used similar rust converting products over the years. They help a lot, but the rust would eventually come back in our heavy salted road environment.
Mine was doing the same thing. Rust was forming in the seams and such. Spraying Fluid Film in the cavities seems to have completely stopped the rust inside the cavities and no more rust creeping out the seams. The Fluid Film continues to creep out of the seams and picks up dirt, but it cleans off real easy. I'm so happy the members here helped me to learn about such product. i love that it's non toxic. I won't have to worry about a rusted out body on a vehicle again, unless I buy it that way already.
Rob K is offline
post #159 of 162 Old 09-24-2019, 01:22 AM
Ralph77
Big fan of Fluid Film. As a matter of fact getting close to my yearly application of it for the winter.
One thing I like about it is how it appears to "condition" metal.
First year I used it I noticed that my front diff, knuckles, etc were a little rust red in appearance. Nothing crazy rust wise.
Well figured when Spring came I would neaten up under there a little.
So when I power washed off all the Fluid Film in April I noticed instead of it looking rust red it had become more of a mud brown in appearance.
Never did do any "housekeeping" there. LOL.
Ralph77 is offline
post #160 of 162 Old 09-24-2019, 04:26 PM Thread Starter
Rob K
1995 XJ Cherokee
Maybe it all doesn't pressure wash off which is why it appears darker. Probably a good thing. Might have to use soap or chemicals and scrub if you ever wanted to get it all off.
Rob K is offline
post #161 of 162 Old 09-24-2019, 07:19 PM Thread Starter
Rob K
1995 XJ Cherokee
So I just figured out what the droning noise is from the front passenger foot well area. There's maybe an 1/8" up and down play where the cv axle enters the axle housing. Apparently it's fairly common for the splines to wear out prematurely on the intermediate shaft. The solution is to replace the cv axle and intermediate shaft. Might as well get an axle housing bearing and seal just in case. I must have knocked loose the crud or rust that was in the splines, plus the drippy paint on the cv axle makes it wobble a little more. That's why I started noticing the droning after working on the that side.
Edit: Axles have been replaced and now I'm down to just tire noise which was probably the bulk of it all along. New axles also have a good deal of play at the axle housing, about the same as the old ones. More than what you would think it should be. Something about the KK makes it sound like there is noise from the front passenger side drivetrain when the tires are noisy. You can rotate the tires around and it still sounds like there is an obvious problem in the front passenger drivetrain. It fooled several people that know their way around vehicles. Maybe less padding and noise dampening in passenger foot well.
Rob K is offline
post #162 of 162 Old 02-08-2020, 07:16 AM Thread Starter
Rob K
1995 XJ Cherokee
Suspension is worn out at 50k miles. Shocks are bad and coil springs are sagging a little. Bought a new Old Man Emu heavy duty kit. Should add 2-2.5" of lift and give me the towing and hauling capacity that I need. Doing an experiment with Chassis Saver. I painted the coil springs with it. We will find out if it is flexible enough to be used in this application. I emailed Magnet Paints to ask them and got no reply again. Apparently they are not good at returning emails.
On a side note the under carriage paint is holding up well after a few years of pressure washing. Apparently thoroughly sanding off all traces of gloss and going over it with 2-3 heavy coats of silver Chassis Saver is adequate. Also I'm guessing the Fluid Film helps to keep the seams and edges from rusting and loosening were a pressure washer would start to peal up the paint. We will see about long term.
And my standard bubbly/runny finish. I don't seem to ever get it right. Probably not thinning enough and putting it on to thick all the time. Also probably need to thin it more as I brush it on. It seems to thicken pretty quick during the application.
Rob K is offline
