Security and TPMS Lights randomly on - JeepForum.com
post #1 of 4 Old 03-29-2020, 04:45 PM Thread Starter
olds72
I have searched the web for answers worh no luck on a correction/fix. My TPMS and Security light coms on randomly. Tires have the correct air pressure and the tire pressure sensors are new(2019). I have read that other people have reported this same issue on other jeeps. Who knows whats going on with my systems?
olds72 is offline
post #2 of 4 Old 03-30-2020, 09:35 PM
Rob K
1995 XJ Cherokee
Starting with the basics. Did you check the spare? The spare tire has a sensor also in case you didn't know. Mine also knows when I'm using the spare tire because the light doesn't go out until I put the spare away. If you have a low tire and you pump it up you have to drive around for a bit for the light to go out.
Rob K is offline
post #3 of 4 Old 04-01-2020, 10:30 AM Thread Starter
olds72
All tire pressure is good. This happens when I'm on the highway traveling 70-80 mph. It started out very randon. Now it will happen 5+ times over an 80 mile drive to work. I had the whole system scanned at the dealer and codes were stored.
olds72 is offline
post #4 of 4 Old 04-02-2020, 09:16 AM
Rob K
1995 XJ Cherokee
I don't know the answer so I did a bunch of research using google. I want to know the fix for this because I may see this happen with mine some day. Apparently this is a common problem with newer jeeps in general not just the liberty. I read a lot of threads but no one had figured it out.
Rob K is offline
