Please help with figuring out suspension upgrade - Page 2 - JeepForum.com
 2Likes
post #16 of 46 Old 11-07-2019, 08:42 PM Thread Starter
Rob K
1995 XJ Cherokee
Need to figure out bump stops. If pucks work for the back I have 5 of those laying around. Front?
Rob K is offline
post #17 of 46 Old 11-07-2019, 09:39 PM
buddy07
2012 KK Liberty
https://notrailrated.com/collections...berty-08-12-kk
2008 Liberty 4x4,OME 1.5" lift, 265x60/18 Duratracs
2012 Liberty 4x4,OME 1.5" lift, LT265x70/16
buddy07 is offline
post #18 of 46 Old 11-08-2019, 06:58 PM
tomknight
tomknight's Avatar
2011 KK Liberty
seems that most folks go with terraflex front bumps. I think you have to cut them down to 2" if you can't get 2" ones.
All of the shocks and springs are available on Amazon Prime. No tax, free 2-day shipping. You can get a trial subscription.
Don't forget the JBA Bilstein adapter kit for the rear if you go with Bilsteins.
2011 Liberty Limited
2006 Liberty Limited
tomknight is offline
post #19 of 46 Old 11-09-2019, 07:17 PM Thread Starter
Rob K
1995 XJ Cherokee
Front factory bump stops measure 1.75" from metal to end of stop. I see that the edges are rounding off so they are getting some wear at 50k miles.
So is 2" going to be tall enough for OME 2-2.5" HD lift? Sorry I'm new to putting together lift kits. I was just reading somewhere that OME coil springs can maybe handle a good deal of compression and maybe get away with smaller bump stops or even the factory bumps? Maybe you buy long and cut them down as needed? I'm sure it depends on tire size also.
Also is looks like pucks will not work in the back. The stops are mounted inside the spring and are pressed in just like the front bump stops.
Rob K is offline
post #20 of 46 Old 11-09-2019, 07:32 PM Thread Starter
Rob K
1995 XJ Cherokee
I think I figured it out. I see several places sell bump stops for a 4" lift and you cut them down for shorter lifts. Just have to figure out how much.
Rob K is offline
post #21 of 46 Old 11-09-2019, 07:52 PM Thread Starter
Rob K
1995 XJ Cherokee
Oh I think I get it. Pucks get bolted to the spring perch. Just have to figure out how tall for the OME HD lift springs and 245/75r16 tires.
Rob K is offline
post #22 of 46 Old 11-10-2019, 06:00 PM
Pine_Cat
Pine_Cat's Avatar
Factory wheels? Do you think when pointed straight ahead those 245s will hit the factory flares?
2017 JK Sahara (my Smartcar)
2011 KK Liberty (H&R lift springs, OldManEmu shocks/struts, skinny 32)
2009 Kia Sorento (H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, skinny 31)
2006 TJ budget LCG prerunner (see profile)
2006 Chevy Trailblazer (EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32)
1998 Dodge Durango (SuspMax & Roadmaster lifts, rear Truetrac, skinny 32)
Pine_Cat is offline
post #23 of 46 Old 11-10-2019, 06:41 PM Thread Starter
Rob K
1995 XJ Cherokee
No idea. Others have installed 245/75R16 30.5" tire with the OME heavy duty springs. I assume the combo works. Pretty sure I read you can do up to a 30.5" tire with these springs. A little smaller would be fine with me also. It would be nice if they were a little bigger than stock though for extra ground clearance.
Rob K is offline
post #24 of 46 Old 11-10-2019, 09:27 PM
tommudd
2004 KJ Liberty
Originally Posted by tomknight View Post
one more - the front springs are 731 for hd use. Not sure what the numbers are for the others.
wrong info
front coils are 927s
tomknight likes this.
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
05 KJ
tommudd is offline
post #25 of 46 Old 11-10-2019, 09:30 PM
tommudd
2004 KJ Liberty
The list:
OME 2731 HD Rear coils
OME N132L HD Rear shocks
OME 2927 HD Front coils
OME 90009 Front Sport strut
Terraflex 3" front bump stop
Or could use Bilstein shocks as well, work good
coil numbers are ok
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
post #26 of 46 Old 11-10-2019, 09:32 PM
tommudd
2004 KJ Liberty
30.5 tall tire works, although you will lose some power and mileage if you do not regear
On one of mine I run 265-70-16s ( 30.6 inches tall with 2.5 inches of lift and 4.10 gearing
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
post #27 of 46 Old 11-10-2019, 09:35 PM
tommudd
2004 KJ Liberty
rear bumpstops use 2 per side hockey pucks bolted down to the lower spring perch , use 2.25 inch long bolts to hold them in , install after you install springs, of course drill holes before installing springs
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
post #28 of 46 Old 11-11-2019, 08:35 AM Thread Starter
Rob K
1995 XJ Cherokee
Tommudd, do you know how about how much rake their is with these springs without adding any spacers? Using just the springs by themselves. With the factory springs I was often using up the whole 1" of rake when loading and hauling so it was riding level. I'm guessing I wouldn't need quite as much rake with the heavy duty springs. I load heavy, but tow light right now. Usually at the same time. I guess that could change.
Based on the comments it sounds like I should look for a 29-30" tire.
The list:
2 x OME 2731 HD Rear coils
2 x OME N132L HD Rear shocks
2 x OME 2927 HD Front coils
2 x OME 90009 Front Sport strut
2 x Teraflex 1903200 3" front bump stop
4 x pucks
2 x 2.25" bolts
Rob K is offline
post #29 of 46 Old 11-11-2019, 04:18 PM
tommudd
2004 KJ Liberty
The list:
4 x pucks
2 x 2.25" bolts
Should sit pretty much level front to back
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
post #30 of 46 Old 11-11-2019, 06:28 PM
tomknight
tomknight's Avatar
2011 KK Liberty
tommudd - thanks for helping out. I was kinda hoping you'd come by and clean this up.
