New Transmission, Now Drive Shaft Leak - JeepForum.com
 1Likes
  • 1 Post By lfhoward
post #1 of 5 Old 07-25-2019, 02:58 PM Thread Starter
ALR1234
Just got the transmission rebuilt on a 2012 last week. In the meantime the wheel studs also went bad and had to get those replaced. While the folks fixing the wheel studs had it up on the lift, they noticed the drive shaft was leaking grease. I was not there so I didn't see it, but we took the Liberty back to the mechanic who fixed the transmission and asked them to take a look. They told us that it will be $500 to fix the issue with the drive shaft and that the leak had nothing to do with the transmission fix. My question is, is it possible to rebuild the transmission without taking the drive shaft off? We have had this vehicle for 2 years and before the transmission went, never had an issue with the drive shaft.
ALR1234 is offline
post #2 of 5 Old 07-25-2019, 07:13 PM
Pine_Cat
Pine_Cat's Avatar
Why did the transmission need to be rebuilt? High mileage? Was it run without enough fluid?
There may be some misunderstandings here. Driveshafts don't contain a reservoir of grease that can spring a leak, so maybe it's something else?
2017 JK
2016 MK- Murchison springs, ~1" BL, skinny 30s
2011 KK- H&R lift springs, OldManEmu shocks/struts, skinny 31s
2009 Sorento- H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, 31s
2006 TJ budget LCG prerunner- see profile
2006 Trailblazer- EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32s
1998 Durango- SuspMax & Roadmaster lifts, rear Truetrac, skinny 32s
Pine_Cat is offline
post #3 of 5 Old 07-25-2019, 08:02 PM
lfhoward
lfhoward's Avatar
2008 KK Liberty
Is it the front drive shaft where it goes into the transfer case (the rear CV joint)? If the rubber boot is toast, this can leak grease and then start to make noises etc.
This CV joint is completely replaceable and you can do it yourself for $36.
https://www.driveshaftparts.com/inde...product_id=566
Pine_Cat likes this.
2008 Liberty Sport 4x4 Automatic
4" JBA Lift & 245/75R16 BFG KO2's
ATH Recovery System & Roof Rack
lfhoward is offline
post #4 of 5 Old 07-26-2019, 07:14 PM
Pine_Cat
Pine_Cat's Avatar
Thanks for chiming - when I experienced your front shaft point I could hear it going, so that's why I came across as skeptical
2017 JK
Pine_Cat is offline
post #5 of 5 Old 07-26-2019, 09:35 PM
lfhoward
lfhoward's Avatar
2008 KK Liberty
No worries! When I first read the post I was picturing the rear driveshaft and for that what you said was absolutely true. But I had the rear CV on my front driveshaft go out a couple of years ago and so thatís what made me think the OP might have a issue on the front shaft. Youíre right, it sounds like chains dragging when itís about to die. But the grease comes out first and dirt gets in, leading to internal carnage and wear. I bet itís in the early stages.
lfhoward is offline
