JeepForum.com (https://www.jeepforum.com/forum/)
-   KK Liberty Forum (https://www.jeepforum.com/forum/f292/)
-   -   New Transmission, Now Drive Shaft Leak (https://www.jeepforum.com/forum/f292/new-transmission-now-drive-shaft-leak-4364807/)
ALR1234 07-25-2019 02:58 PM
Just got the transmission rebuilt on a 2012 last week. In the meantime the wheel studs also went bad and had to get those replaced. While the folks fixing the wheel studs had it up on the lift, they noticed the drive shaft was leaking grease. I was not there so I didn't see it, but we took the Liberty back to the mechanic who fixed the transmission and asked them to take a look. They told us that it will be $500 to fix the issue with the drive shaft and that the leak had nothing to do with the transmission fix. My question is, is it possible to rebuild the transmission without taking the drive shaft off? We have had this vehicle for 2 years and before the transmission went, never had an issue with the drive shaft.
Pine_Cat 07-25-2019 07:13 PM
Why did the transmission need to be rebuilt? High mileage? Was it run without enough fluid?
There may be some misunderstandings here. Driveshafts don't contain a reservoir of grease that can spring a leak, so maybe it's something else?
lfhoward 07-25-2019 08:02 PM
Is it the front drive shaft where it goes into the transfer case (the rear CV joint)? If the rubber boot is toast, this can leak grease and then start to make noises etc.
This CV joint is completely replaceable and you can do it yourself for $36.
https://www.driveshaftparts.com/inde...product_id=566
Pine_Cat 07-26-2019 07:14 PM
Thanks for chiming - when I experienced your front shaft point I could hear it going, so that's why I came across as skeptical
lfhoward 07-26-2019 09:35 PM
No worries! When I first read the post I was picturing the rear driveshaft and for that what you said was absolutely true. But I had the rear CV on my front driveshaft go out a couple of years ago and so thatís what made me think the OP might have a issue on the front shaft. Youíre right, it sounds like chains dragging when itís about to die. But the grease comes out first and dirt gets in, leading to internal carnage and wear. I bet itís in the early stages.
The time now is 10:51 PM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
