Heat is blowing cold air. - JeepForum.com
 10Likes
post #1 of 39 Old 11-19-2014, 06:03 AM Thread Starter
2011Liberty
2011 KK Liberty
I have the same issue with my 2011 Jeep liberty sport. I will not blow hot air at all. When i turn the dial to hot setting and push the A/C button in, the air only gets colder.
The blower works great. All the vents blow air. It is just cold.
Could it possibly be the Blend door motor or actuator being stuck on the cold side and not switching over to the hot side?
The heat worked fine the morning before.
Do you think i should look into a radiator flush.
I changed out the thermostat and that wasn't the problem. The fluid has some nasty stuff in the antifreeze.
The vehicle has 84k on it.
2011Liberty is offline
post #2 of 39 Old 11-19-2014, 06:25 AM
CollinKK
2008 KK Liberty
I'd definitely look into flushing out the heater core. My 08 had the exact same problem as you're describing. It didn't bring it back to what it once was, so I might have to do it again, but it definitely will make the winter bearable here in CT
CollinKK is offline
post #3 of 39 Old 11-19-2014, 07:24 AM Thread Starter
2011Liberty
2011 KK Liberty
Did that fix your problem and make the heat turn back on.
Is there a way to check to see if the heater blend door is bad?
Also how much does that usually cost to get the flush done?
post #4 of 39 Old 11-19-2014, 07:26 AM
Batty505a
It's a stuck thermostat!
Had that happen in my 93YJ
it's a cheap easy fix if you have a heated garage.
If you're in the snow belt, you may wanna consider having it done
HTH
2006 Chevy Silverado (DD)
1998 Jeep TJ Wrangler Sport (DD)
1993 Jeep YJ Wrangler *Parts Vehicle*
Batty505a is offline
post #5 of 39 Old 11-19-2014, 07:49 AM Thread Starter
2011Liberty
2011 KK Liberty
I already changed the thermostat on the vehicle.
That didn't do anything. The thermostat was fine.
Any other suggestions that it could be?
post #6 of 39 Old 11-19-2014, 09:38 AM
lfhoward
lfhoward's Avatar
2008 KK Liberty
I just found this thread over on LOST and it might solve your problem.
http://www.lostjeeps.com/forum/phpBB...p?f=88&t=76917
2008 Liberty Sport 4x4 Automatic
4" JBA Lift & 245/75R16 BFG KO2's
ATH Recovery System & Roof Rack
lfhoward is offline
post #7 of 39 Old 11-20-2014, 04:41 PM
Batty505a
Originally Posted by 2011Liberty
I already changed the thermostat on the vehicle. That didn't do anything. The thermostat was fine. Any other suggestions that it could be?
MeÁhanic?
post #8 of 39 Old 11-28-2014, 11:43 PM
dpa43
2008 KK Liberty
I had the same issue on my 08. I checked the blend door motors and they both worked. I then checked the aluminum heater core pipes inside the dash after the Jeep ran for about 20 minutes to get the fluid hot. One of the pipes was very hot to the touch and the other was barely warm. I had the heater core flushed and that solved the issue. Check the pipes and that should help resolve the issue if its a clogged heater core.
The Fleet:
2008 Jeep Liberty,2010 Ford Fusion
2007 Chrysler Sebring, 2000 Ford Windstar
1999 Ford Contour SVT
dpa43 is offline
post #9 of 39 Old 11-18-2015, 07:55 PM
BamaAggie
2009 Jeep Liberty Sport: Heater blowing cold air
My heater has worked great on my 2009 Jeep Liberty Sport until I needed it this Fall during an early cold snap. Fan works great but just blowing cold air. Took it to dealer and they claimed the AC/Heater Actuator Plate needed replacing. Paid over $200 for replacement and heater is still just blowing cold air. They, now, say the heater core may be partially blocked. I paid them to flush coolant, but still heater is blowing less than 50% warm air as it originally did. They say, the heater core may need to be replaced, but that requires removing the dash and their service department acts like they do not want to work on it... too busy.
Is there a way to unblock the heater core (if that is the real problem) without removing the dash?
Wakahoe56 likes this.
BamaAggie is offline
post #10 of 39 Old 11-20-2015, 08:43 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey BamaAggie,
I am sorry to hear about your recent experience with your Liberty. I could not locate any service bulletins related to your heating concern. Have you had the vehicle diagnosed at a second FCA certified dealership?
JeepCares is online now
post #11 of 39 Old 12-29-2015, 11:04 AM
mike134
Sorry man, that's total bull****. Some of these dealer service centers are filled with idiots. I'd file a complaint with the Better Business Bureau. (against the service center, not against jeep).
It is very obvious when the heater core is clogged. When this is the case, the inlet hose is HOT and the outlet hose is COLD. After checking the coolant level and thermostat, hose temperature is VERY high up on the list of things to check, it takes 3 seconds and directly confirms whether you need a $1200 repair. If they did not do that the very first time you had issues with the heat, then they are taking you for a ride or are ignorant or lazy. It doesn't matter which one, go somewhere else.
Let JeepCares help you with this. They need to get their house in order as far as service centers go... Jeep corporate is probably just as frustrated as you with the ****ty mechanics. Still though, they need to get this taken care of. 30 years of crappy dealerships is just not acceptable in the face of the changing economic structure where dealers are absolutely NOT a necessary part of the distribution system. (They are literally lobbied and legislated into the law of most states to mandate their existence, because they don't need to exist. i.e. Tesla was not allowed to sell Teslas on the internet without a dealership in the state of Ohio...).
I think what is happening is not that they 'don't want to work on it', the problem is that they don't know how to fix it, and as they keep taking money out of your pocket for repairs that don't work, they know the possibility of small claims lawsuit and/or class action is adding up quickly.
rgamel likes this.
mike134 is offline
post #12 of 39 Old 11-20-2017, 10:15 AM
mikiey
I have the same issue with my 2012 liberty. have flushed the system, nothing came out but clear water. changed the thermostat. checked all three of the door actuators working fine. it got a little warmer but this morning nothing.
mikiey is offline
post #13 of 39 Old 11-20-2017, 05:57 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Like some others, I had to back flush the heater core with a garden hose for 30+ minutes to get sufficient flow for decent heat. A good rate of clear water was running through the entire time.
In my case, both the inlet and outlet hoses were pretty warm, but I was not getting any warmth in the cabin (just enough to tell that the blend door was working). I'm not sure how good the hose temperature test is for a partially blocked liberty (2009) heater core.
I don't think a basic everyday coolant flush is sufficient to clean out the heater core, you need to address the core directly for an extended length of time before giving up on it.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #14 of 39 Old 10-31-2019, 08:32 AM
deanallen1969
Heater Blowing hot for 10 seconds then Freezing cold continuously
Hi, I have a Jeep Liberty 2009 (badged as a Cherokee as I'm in the UK). I read with interest about the heater core problems as mine is driving me crazy. When I put the heater blower on, it does blow hot air for 5 to 10 seconds, then it turns icy cold and never warms up. I suspected the heater core after reading this site, so connected a hose to one side and ran clean water for 10 minutes without problem. I connected to the other side and again ran clean water for 10 minutes without a problem. It therefore seems that I don't have a heater core issue. I had a local mechanic check the thermostat without any issues. I took it to Jeep UK who stated that they would still like to replace the heater core and quoted me £1480 british pounds. i clearly want to avoid that, especially as I've flushed it without issues.
The fact that it blows warm for a short while and then freezing cold - could there be some sort of internal thermostat inside the car thats giving the heater system the wrong information ?
I'm really at a loss with this.. thanks.
deanallen1969 is offline
post #15 of 39 Old 11-06-2019, 10:57 AM
Robinr01
Sorry guy's but I fear that most of you are in for a large repair bill. I also had similar issues about a year ago with my 2010 Liberty w/defrost and panel working and diminished cooling / heat. I looked at actuators and all functioned as required. The problem was that several gears, (plastic), had stripped and doors would not function as designed. The root cause was the sealant used close off the HVAC united degrades over time and melts down onto the doors and seals them shut, (no recall or service bulletin). I understand that this is a common problem with the liberty and requires complete dish removal ($$$). Also recommended heater core replacement, (another weak point), while dash is out.
robinr01
Robinr01 is offline
