Cruise Control sometimes refuses to turn on - JeepForum.com
post #1 of 3 Old 06-21-2021, 09:53 AM Thread Starter
david.karr
I have a 2012 Jeep Liberty with relatively low mileage.
I find that some days when I try to turn on cruise control, it simply refuses to turn on. When this happens, it usually does this all day, even if I stop and park for a while. Other days it works perfectly fine. I used to think it was cold days it refused to turn on, but that's not consistent.
I could bring it in to be serviced, but I thought I would ask about this first to see if there is an easy solution. Is there anything I can do before I give up and bring it in?
david.karr is offline
post #2 of 3 Old 06-21-2021, 11:34 AM
pshivers
2008 KK Liberty
My switch has been giving me issues. I can enable cruise. I have to push down hard to lock in a speed. If I try to cancel cruise via the switch, it will disable cruise until I restart. Switches are cheap and relatively easy to change. The alternative is to hook up a scan tool and see if the switch inputs are being seen by the computer.
Sent from my Samsung S8+ using Tapatalk
pshivers is offline
post #3 of 3 Old 06-21-2021, 06:36 PM
Pine_Cat
Pine_Cat's Avatar
Could be a TIPM glitch? The scan tool sounds like a good idea, to begin thinking about trouble-shooting. I keep putting it off because the issue is only occasional.
2017 JK
2016 MK- Murchison springs, ~1" BL, skinny 30s
2011 KK- H&R lift springs, OldManEmu shocks/struts, skinny 31s
2009 Sorento- H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, 31s
2006 TJ budget LCG prerunner- see profile
2006 Trailblazer- EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32s
1998 Durango- SuspMax & Roadmaster lifts, rear Truetrac, skinny 32s
Pine_Cat is offline
