2010 KK crank issue - JeepForum.com
post #1 of 12 Old 09-09-2021, 03:41 PM Thread Starter
97_JGC
2010 KK crank issue
Has anyone experienced this " no crank " issue. Used to do it very intermittently, once every few months, becoming increasingly common, 5 - 10 times in a row every couple of weeks. You can hear the starter engage and then "die out". Both starter and battery are new, battery connections clean and tight. No codes.
97_JGC is offline
post #2 of 12 Old 09-23-2021, 06:07 AM
mikecs4life
mikecs4life's Avatar
Im having the same issue. It engages for a half a second then stops. After 15-20 tries it will fire. I now have it jumped to a toggle switch from the relay and it cranks and starts every time, so its not the starter, ignition switch, or fuses. Any help would be greatly appreciated.
mikecs4life is offline
post #3 of 12 Old 09-23-2021, 09:21 AM
Ex-Calif
2012 KK Liberty
For both of you it sounds like it could be a bad start relay. Here is a cool video I found that has a quick "relay swap" that you can test with.
2012 Liberty Sport
WWII - Horses vs. Jeeps - 'nuff said...
Ex-Calif is offline
post #4 of 12 Old 09-26-2021, 11:23 AM Thread Starter
97_JGC
[QUOTE=Ex-Calif;41361015]For both of you it sounds like it could be a bad start relay. Here is a cool video I found that has a quick "relay swap" that you can test with.
Thank you for the suggestion, ordered a new relay this morning. Does not seem to be a very common issue, only came across one thread in a Nitro forum.
97_JGC is offline
post #5 of 12 Old 09-27-2021, 07:04 AM
Ex-Calif
2012 KK Liberty
Did you do the relay swap first? Was that the issue?
2012 Liberty Sport
Ex-Calif is offline
post #6 of 12 Old 09-27-2021, 01:51 PM Thread Starter
97_JGC
No my issue is still fairly intermittent, for the $20 I will just replace with a new one and see over time if that was the issue.
97_JGC is offline
post #7 of 12 Old 09-30-2021, 12:32 PM
raider56
raider56's Avatar
I have the same intermittent issue, I even have Major Guard and all they did was change the started which didn't work on the problem. There was a Star case on it that referenced bad grounds, but it was never found. Never heard of the relay fix.
Does anyone know what relay to order to swap it out?
Thanks!
raider56 is offline
post #8 of 12 Old 10-01-2021, 04:13 PM Thread Starter
97_JGC
Thanks!
I found the location of my starter relay on this page.
https://fuse-box.info/jeep/jeep-libe...ses-and-relays
The part number itself I got off the factory relay which is located in the fuse box right behind the battery.
I just installed the new relay today so time will tell if that is the issue. I found someone with a Dodge Nitro [which is essentially what are Libby's are] and a new relay did NOT solve his issue. Whether he changed the correct one or not who knows. He had also changed the starter, battery and ignition switch with no success. Not much left after all that I suppose. Watch Wes Work described our ignition system as overly complicated. He goes into the schematic in this video.
Will report back to this thread either way.
97_JGC is offline
post #9 of 12 Old 10-03-2021, 05:13 AM
Ex-Calif
2012 KK Liberty
I'd love to hear the results. It could be the ignition switch on the column itself as well, I suppose.
2012 Liberty Sport
Ex-Calif is offline
post #10 of 12 Old 10-03-2021, 09:10 AM Thread Starter
97_JGC
The fella that had the Nitro had a garage swap out his ignition switch but he still had the issue. If the problem persists with the new relay I will swap the ignition switch out anyway.
97_JGC is offline
post #11 of 12 Old 10-23-2021, 03:32 PM Thread Starter
97_JGC
Well, unfortunately the new relay did not solve the issue. Maybe got 15 or so normal starts until it occurred again.
97_JGC is offline
post #12 of 12 Old Yesterday, 06:47 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Someone had something similar on another forum here. He initially replaced the starter with no joy but after a bunch of dead end troubleshooting, replaced with another starter and that worked for him. But I would double check the condition of all the grounds and battery voltage while trying to start before trying another starter.
I just got lost in thought. It was unfamiliar territory;
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
