2010 Jeep Liberty - "No Fuse" - JeepForum.com
post #1 of 3 Old 09-20-2021, 07:02 AM Thread Starter
KevinNJ25
Hi,
I'm in a perdiciment here and was looking for some assistance. To begin, my 2010 Liberty has been idle in my driveway for about 18 months. I'm preparing to sell my home and need to get this Jeep up and running to get it out of the driveway. As I entered the vehicle this morning I put the key into the ignition and was greeted with a 'nofuse' error on the Dash. I figured it was a battery issue so hooked up my trickle charger. After about 10 minutes the charger read fully charged. My research thus far led me to believe there is a fuse (obviously) not working as expected. My question is how should I go about finding the fuse in question. Absolutely nothing works when I put the key in, radio, lights, locks etc.
KevinNJ25 is offline
post #2 of 3 Old 09-20-2021, 07:19 PM
Rob K
1995 XJ Cherokee
Google search says no voltage to J13 IOD 60amp fuse can cause that error message. I'd start by checking that fuse in the engine compartment. Making sure it's good, the connections are clean and not corroded, and making sure it's seated properly. Check for 12v to that fuse with a voltmeter. If that doesn't reveal the problem then I'd be checking and re-seating all the fuses and relays in that box. If still not fixed would check and re-seat all the wiring connectors to the fuse box. All connections will get oxidation over time and eventually start to overheat or corrode.
Rob K is offline
post #3 of 3 Old 09-25-2021, 08:43 PM
Boojo35
1987 YJ Wrangler
J13 feeds a 20 amp fuse labled m13. If that fuse is bad you will get that message. I know that for fact, I saw it on a 09 a couple of days ago.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
