Problems with electrical Jeep Registry
Previous Jeep JK Wrangler Next Jeep
Email Bookmark Print
SouthpawHunter
Jeep Information
I have a 2013 Jeep Wrangler JKU. Ive had zero problems with it until the other day while off roading when I shut it off and it wouldn't start. The m27 fuse (ignition switch) was blown. Started back up drive about 4 miles when the jeep lost throttle control and died. The ignition switch and the vacuum pump fuses were blown now. Jeep has full battery power and when I replace those fuses they just pop when I attempt to turn it over. The red lightning bolt was not on while the vehicle was running but it stays on when I turn the key over to run. Where do I start looking to fix my baby and get her back off the road? Thank you in advance. Also I drive a manual in case that matters.
None
