Tj with the transfer case Jeep Registry
Previous Jeep TJ Wrangler Next Jeep
Email Bookmark Print
Rino350
Jeep Information
Hello all I'm new to this forum and new to Jeeps. I recently picked up a 99 TJ pretty cheap but it has a few things that needs to be done to it (obviously). One thing that has already been done is a transfer case swap. The previous owner put a YJ transfer case in but he hasn't ever hooked up the front drive line. My assumption is that I need to use a YJ front drive shaft and put a TJ yolk on diff end but you know what assuming does..
Also the shift handle for the YJ transfer case sits in the wrong position. It looks like even with a drive shaft I will only be able to shift from 2H to Neutral. What's the best way to fix this? I was thinking about modifying the handle but maybe I could replace it with a TJ handle to make it set in the right position?
None
