nc1bruva Jeep Registry
Previous Jeep TJ Wrangler Next Jeep
nc1bruva
Email Bookmark Print
nc1bruva2000
Picton
Jeep Information
Year:2000
Model:tj
Engine:4.0
Transmission:stick
Hello. any suggestion would be great. All lights outside my jeep work, however when I turn/use my left signal indicator my speedometer blinks and on the outside the turning lights and back lights also blink on and off as if the hazards are on. All fuses are fine new flasher relay as well, and using the right turn indicator is all good.
None
Login Or Register To Post Comments
nc1bruva2000
View nc1bruva2000's Jeep
07-10-2020, 01:46 PM
Forgot to add, under my steering wheel with the panel off I also noticed which looks like a ground wire (round with triangle edges inside) is loose. Could this be the problem can seem to see where it goes back
