Can anyone identify what fell out of my AX15 transmission Jeep Registry
Previous Jeep TJ Wrangler Next Jeep
Email Bookmark Print
donovan53
Florence
Jeep Information
Hello, I am in the process of replacing the throw-out bearing in my 99 Wrangler with the AX-15 I had a hard time separating the transmission from the engine but after some fighting it finally came loose. After getting it on the ground I found this,which I believe is some sort of bearing? It was laying on the ground. I have done lots of research and was thinking it was the pilot bearing until I removed the pressure/clutch plate and saw the the pilot bearing is much bigger. I pulled the transmisson and transfer case (NP231) as one. If anyone can help me identify this piece I would greatly appreciate it.
None
