Brake issue Jeep Registry
Previous Jeep TJ Wrangler Next Jeep
Brake issue
Email Bookmark Print
Ești
Jeep Information
If the brake pedal is depressed and constant pressure is held it will work, but if you let off pressure a little and try to press again, the pedal goes down further. If you let off pressure a second time and try to press the pedal it goes all the way to the floor. The flash red BRAKE light is on. No leaks anywhere and fluid resovoir is full.
None
