2006 tj rubicon no crank Jeep Registry
Previous Jeep TJ Wrangler Next Jeep
Email Bookmark Print
Laurenzo996
Jeep Information
Hi! I have an issue with my jeep. I turn the key and the engine wont turn over.
My jeep is a rubicon 2006 4.0l auto trans
Here is what I checked so far:
Batterie is good and charged.
Starter is new and works when i jump it
Ign accuator pin is ok.
I replaced the main ground cables and starp.
I dont get pcm connection when i try to get a ob2 reading.
When I try to turn the key to the run position. the fuel pump relay does a rappid clicking sound the starter does only one clic and then stops..
Some one can give me the reading you get at the fuel pump relay with a volt meter plz?
At this point i dont know what to check help.
None
