1998 TJ 2.5L manual Jeep Registry
Previous Jeep TJ Wrangler Next Jeep
1998 TJ 2.5L manual
Email Bookmark Print
Telliott11
Jeep Information
Clean but can’t figure out why it decided after running now it has no spark. Ok now I am completely lost. I really need help. I have replaced the Cam sensor crank sensor female plug on cam sensor. Replaced the pcm ignition coil while distributor is new (ran with it ).
This is what happened. Replaced the exhaust manifold cranked when done ran for good 45 to hour. Turned off sat for about one minute and then tried to crank it with no luck turns over fuel pump primes but no spark and that lead me to replacing all the above stuff. I am at my wits end now. HELP
None
