YJ Wrangler check engine code 25 Jeep Registry
Previous Jeep YJ Wrangler Next Jeep
Email Bookmark Print
OhNo2
Jeep Information
Hello!
My 95 Wrangler (I4 manual) has been throwing check engine code 25. I have been trying to fix it, but can’t get it to stop. I clear codes after everything I replace.
So far I have:
- Cleaned the throttle body
- Replaced idle air speed control motor
- Replaced the throttle position sensor
- Replaced the MAP sensor
- Replaced any obviously cracked hoses/connectors.
What my Jeep is doing:
The check engine light comes on randomly while I am driving. It does not come on while I am idling in my driveway, even if I leave it on for extended periods of time. (I idle between 750-1000rpm).
So far it has come on at:
13m 03s
12m 20s
31m 34s
As I have replaced nearly everything (short of every single air hose in the Jeep) I am running out of ideas. Can anyone help? Thanks!
None
