!!!!HELP Starting issue getting worse!!!! Jeep Registry
Previous Jeep YJ Wrangler Next Jeep
Email Bookmark Print
Snappyalemouse
Jeep Information
Good day Jeeple
I’m have a starting issue with my 91. The issue is when I turn the key the maintenance required light is the only light that comes on. No check engine light on startup. I have replaced the fuel pump relay. For me to get the Jeep to a starting condition I have to leave the key in the on position pull the fuel pump relay and place it back in with power on and wait 30-50 seconds then I’ll hear the relay kick over and the fuel rail prime At This time is when the check engine light comes on and goes through normal start scenario. Will do this when engine is cold but will start normally after it has been running. I have swapped out all the relays, all fuses, fuel pump,and fuel filter. Does anyone have any other suggestions.
None
