1990 Jeep Wranger YJ Sahara Jeep Registry
Previous Jeep YJ Wrangler Next Jeep
Email Bookmark Print
IlDavo
San Diego
Jeep Information
1990 Jeep Wranger YJ Sahara Details:
Purchased, new in 1990
127,000 original miles
Original 6-cyl 4.2L (258 cu in) engine — recently serviced
5-speed Manual Transmission
Original factory soft top
Factory air conditioning (does not work — ability to restore unknown, as I’ve had no need of it)
Speedometer reflects correct speed, due to differential gearing that corrects for oversized tires
Tachometer does not function, due to Mopar EFI kit’s required check engine light for smog compliance
Modifications:
Power:
Mopar Multiport Elenctronic Fuel Injection (better fuel mileage, passes CA smog, greater power, runs well even on steep inclines)
CARB-approved Borla header
CARB-approved Borla cat-back exhaust (retained OEM catalytic converter for smog compliance)
Strength/Endurance:
Dynatrac “High Clearance” Dana 60 rearend
M.I.T. transfer case slip yoke eliminator and C.V. driveshaft (reduces driveline vibration)
Extended-travel front driveshaft
Brand new center force clutch
Brand new Advance Adapters clutch slave cylinder relocation bell housing
Brand new clutch slave cylinder
Wrangler Power Products dual battery kit
Dual AGM batteries (3 years old)
Suspension Flex:
Spring-Over-Axle conversion (increased tire clearance, while maintaining suspension flex)
M.O.R.E. front shackle reversal with quarter-hyper-elyptical frame attachment (extreme front suspension travel)
Trail/Rock Crawling Control:
ARB air lockers front and rear
Terraflex Terra-Low 4-to-1 transfer case with 2-wheel-low option
410 gears (ideal for 33” tires, adequate for current 35” tires)
35 inch Dick Cepek tires on dual-valve Eagle Alloy wheels
JKS Swaybar Disconnects
Convenience:
28 gallon gas tack with skid plate
On-board Air Compressor
On-board hot-water shower (pump + heat exchanger)
2020 stereo with bluetooth, remote, USB
Dual-door lockable center console
Canyon City dual-jerry-can tire carrier, with reinforced tailgate mount
Custom jamboree rack
New Water and fuel jerry cans
Warn fender flares (to make larger tires street-legal)
Trail Function:
LED projector headlights
PIAA driving/fog lamps
LED fog lamps
“Bulletproof” tubular front bumper with integral winch roller fairlead
Ramsey winch
Wired for CB radio and scanner, with antenna mounts
Hi-lift trail jack
Includes:
Fabric bikini top
Rear tonneau cover
Plastic window storage roll
Known Issues:
Steering box may soon need replacement
Front drag link frame attachment needs weld repair
All shock absorbers and steering stabilizer need replacement
Driver-side upper half-door cannot be unzipped
Extras/Spare Parts Available on Request:
Spare rear driveshaft (for quick trail repairs)
Brand new OEM front tie rod ends
’Net: This Jeep is the ideal “trail toy.” It’s definitely no “trailer queen.” It has suffered *no* major trail damage, but it does have some minor scratches, dents and imperfections. I can honestly say that I, as the driver, have presented the only limitation as to where this Jeep can go: It has the power and flex to crawl over almost any obstacle that the driver has the guts to try. Details:
Modifications:
Power:
Strength/Endurance:
Suspension Flex:
Convenience:
Trail Function:
LED fog lamps
Ramsey winch
Hi-lift trail jack
Includes:
Fabric bikini top
Rear tonneau cover
Known Issues:
None
