davcono Jeep Registry
Previous Jeep CJ-7 Next Jeep
davcono
Email Bookmark Print
davcono
New Iberia
Jeep Information
Year:1984
Model:CJ7
Engine:350/330
Transmission:AX-15
Transfer Case:D300
Front Axle:D30
Rear Axle:D44
Axle Gear Ratio:3.31
Suspension:Stock
Tires:31" General Grabber AT2
Wheels:ProComp 1069 15x7
Armor:none
Recovery Gear:none
Accessories:PS, PB, AC, Speedhut Gauges, Flaming River SS Tilt Column, Kentrol SS Fittings, LED lighting
Future Modifications:I'm done.
1984 Jeep CJ7 (Steel Body – Arizona – No Rust)
• VIN – 1JCCF87A0ET140093
• New Engine Chevy 350/330 GM 19210009 "10243880”
• Edelbrock 1906 AVS2 Carb
• Ceramic Headers
• Dana 30 Front (Factory)"C67371" "5363734" "3:31" "43 13"
• New Tie Rod Ends
• New front wheel bearings
• New front spindle bearings
• New front U-joints
• New front ball joints
• New Aisin Warner AX15 Five Speed Overdrive Transmission "52108050" "TJA320700003" "P52108050"
• New East Coast Gear and Supply Dana 44 Rear 3:31 Power Trax Grip Pro 30 spline. One-piece axles."1512072" "044CF120" "44-1"
• Dana 300 Transfer Case – Rebuilt - BWC300-15-2, s/n312839, Tag 309007-4,5364854
• Novak aluminum radiator with electric fan
• Stainless radiator expansion tank
• Stainless windshield washer reservoir
• Edelbrock 1791 electric fuel pump with 1795 relay
• Pro Comp 1069 15 x 8 Wheels with Wheel Locks and Stainless Lugs
• Mile Marker 470 Hubs
• Bilstein Shocks and Steering Damper
• Air Conditioning
• Power Steering
• Four Wheel Power Disc Brakes
• Leed Brakes Booster/Master Chrome over Aluminum
• New Disc/Disc Proportioning Valve
• Hydraulic Brake Light Switch
• Hydraulic Clutch
• OEM Chrome Grill and OEM Frame Cover
• Kentrol hinges and trim parts (Polished Stainless)
• Pro Comp Front and Rear powder coated bumpers with polished stainless shackles.
• New Bushings throughout
• New fuel tank, sender, filler neck, cap, hoses
• Custom-made Triple Plated Gearshift and Transfer Case Shifter
• Grant 1150 Steering Wheel with Billet Horn
• Flaming River Tilt Polished Stainless Steering Column
• Custom Auto Sound Stereo with 4 Marine Speakers. USB, CD, MP3, iPod capable. 300 Watts.
• New 31 inch Tires
• LED lighting throughout
• Kentrol SS Dash. New Dash Pad. Kentrol Wiper Motor Cover.
• Speedhut Electronic Gauges. Daylight – White Face. Night time – Red Glow Numerals and pointers with intensity controls. GPS Speedometer (CJ style),.clock, tach, oil pressure, volts, vacuum, and fuel pressure. Fully customized dash with custom made matching knobs, custom made grab bar, radio faceplate, clock and tach adjustment dash indicator lights. Indicator lights glow red to match dash lights.
• Underhood LED Lighting
• Red LED interior lights
• New Windshield and Gasket
• Powder coated Spare Rack and Seat Supports
• Fully Carpeted
None
Login Or Register To Post Comments
AWall23
View AWall23's Jeep
10-08-2020, 10:15 AM
Did you have any issues with your blinkers not working with the LED replacements?
davcono
View davcono's Jeep
10-09-2020, 05:23 PM
84 CJ7 Turn signals
All lighting is stock with LED bulbs from Super Bright LEDs, except headlights which are LED. Installed 50w 60 ohm load resistors in the tail lights bought on Amazon. Installed heavy duty flashers. As I recall there are two. The only problem I have is when my lights are turned on turn signal indicators stay on solid. Otherwise everything works as it should. My instruments are Speedhut electronic.
