cj7 Jeep Registry
Previous Jeep CJ-7 Next Jeep
cj7
Email Bookmark Print
davcono
New Iberia
Jeep Information
Year:1984
Model:Renegade
Engine:350 Chevy
Transmission:AX-15
Transfer Case:D300
Front Axle:D30
Rear Axle:D44
Axle Gear Ratio:3.31
Suspension:Stock
Tires:General Grabber AT2
Wheels:Pro Comp 15x8
Armor:None
Recovery Gear:None
Accessories:Loaded
Future Modifications:?
1984 Jeep CJ7 (Steel Body – Arizona/California – No Rust)
• VIN – 1JCCF87A0ET140093.
• New Engine Chevy 350/330 GM 19210009 "10243880” .
• Edelbrock 1906 AVS2 Carb.
• New Aisin Warner AX15 Five Speed Overdrive Transmission "52108050" "TJA320700003" "P52108050".
• New East Coast Gear and Supply Dana 44 Rear 3:31 Power Trax Grip Pro 30 spline. One-piece axles."1512072" "044CF120" "44-1".
• Dana 300 Transfer Case – Rebuilt - BWC300-15-2, s/n312839, Tag 309007-4,5364854.
• Novak aluminum radiator with Spal electric fan.
• Stainless radiator expansion tank.
• Ceramic Headers with locking collector bolts.
• Dana 30 Front (Factory)"C67371" "5363734" "3:31" "43 13".
• New Tie Rod Ends, front wheel bearings, spindle bearings, and U-joints.
• Stainless windshield washer reservoir.
• Polished stainless wiper arms and blades.
• Edelbrock 1791 electric fuel pump with 1795 relay.
• Pro Comp 1069 15 x 8 Wheels with Wheel Locks and Stainless Lugs.
• Mile Marker 470 Hubs.
• Bilstein Shocks and Steering Damper.
• Air Conditioning.
• Power Steering.
• Four Wheel Power Disc Brakes.
• Leed Brakes Booster/Master Chrome over Aluminum.
• New Disc/Disc Proportioning Valve.
• New brake balance adjusting valve.
• Hydraulic Brake Light Switch.
• Hydraulic Clutch.
• OEM Chrome Grill and OEM Frame Cover.
• Kentrol polished stainless hinges, fuel tank cover, differential covers, and other trim parts..
• Pro Comp Front and Rear powder coated bumpers with polished stainless shackles.
• New Bushings throughout.
• All fasteners, stainless steel or cadmium.
• New fuel tank, sender, filler neck, cap, hoses.
• Custom-made Triple Plated Gearshift and Transfer Case Shifter.
• Grant 1150 Steering Wheel with Billet Horn.
• Flaming River Tilt Polished Stainless Steering Column.
• Custom Auto Sound Stereo with 4 Marine Speakers. USB, CD, MP3, iPod capable. 300 Watts.
• New 31 inch General Grabber AT2 tires.
• LED lighting throughout.
• Kentrol SS Dash. New Dash Pad. Kentrol Wiper Motor Cover.
• Speedhut Electronic Gauges. Daylight – White Face. Night time – Red Glow Numerals and pointers with intensity controls. GPS Speedometer (CJ style),.clock, tach, oil pressure, oil temp, volts, vacuum, and fuel pressure. Fully customized dash with custom made matching knobs, custom made grab bar, fuel pump switch, clock and tach adjustment dash indicator lights. Interior lights glow red to match dash lights.
• Underhood LED Lighting.
• New Windshield and Gasket.
• Powder coated Spare Rack and Seat Supports.
• Fully Carpeted with Lloyds mats.
• Billet pedals.
None
Login Or Register To Post Comments
