CJ7 Jeep Registry
Previous Jeep CJ-7 Next Jeep
CJ7
Email Bookmark Print
AMC84
Richmond
Jeep Information
Year:1984
Model:CJ7 Laredo
Engine:AMC 360 CI, MegaSquirt stand alone DIY EFI with GM throttle body, wideband O2,
Transmission:NP435
Transfer Case:Dana 300
Front Axle:80 Wagoneer Dana 44, spartan locker, warn hubs, 5x5.5 swap, Poison Spyder high steer arm with 1"x.25"thick DOM steering links,1 ton rod ends.
Rear Axle:68 Ford Bronco 9", TEN chromoly shafts, Detroit locker, Motive gears
Axle Gear Ratio:3.70/3.73
Suspension:Spring over with stock springs, custom front outboard kit
Tires:35x12.50R15 BFGoodrich KM2
Wheels:Cragar 315 Nomads (i think)
Armor:Poison Spyder Rocker Knockers
Recovery Gear:Tow straps, Badlands 12k lbs winch with warn winch plate
Future Modifications:Track bar, add on cage, 5 point harness, D60/14Bolt install with rear stretch
Other mods:
-Motobilt YJ fuel cell, with pump and Earls braided fuel line
-PRP seats
-YJ tub swap
-Monstaliner "Midnight special paint"
-Tom woods drive shafts F/R with rear CV conversion
-AutoMeter gauges
-Tablet with ShadowDash app for EFI
-Painless wiring harness
-Northern radiator with Volvo 3500CFM fan
-DUI HEI distributor, Locked out weights and vac advanced, modified to be controlled by MegaSquirt EFI system
None
Login Or Register To Post Comments
