1976 cj5 Jeep Registry
Previous Jeep CJ-5 Next Jeep
1976 cj5
Email Bookmark Print
cglax6
Tidewater
Jeep Information
Year:1976
Model:CJ-5
Engine:304
Transmission:T18
Transfer Case:D20
Front Axle:D30
Rear Axle:D44
Axle Gear Ratio:3.73
Suspension:2.5" BDS lift w/ Bilstein 5125s
Tires:31x10.5x15
Wheels:15" Cragar
Future Modifications:351w swap
Owned since 2017 and been chipping away at PO problems since I got it. Body, frame, paint and axles were in great shape, but as I dig deeper, a lot of issues presented themselves. For instance, he swapped in a narrow track D44 in the rear and cut the spring perches to point the yoke right at the TC output...great an all, but he had a normal drive shaft in. Put in a TW CV shaft in and it cured the nasty vibrations.
Too many other issues to list, so I went ahead and decided to gut the engine compartment, wiring and gauges. In the process of swapping in a 351w w/ Sniper EFI & Hyperspark Ignition, Painless wiring harness and Speedhut gauges.
I'll post a build thread at some point.
None
Login Or Register To Post Comments
