Transmission slow change - JeepForum.com
post #1 of 7 Old 02-28-2020, 04:44 AM Thread Starter
Esorlegin
Hi Guys.
Just bought another Jeep - Jeep Cherokee KJ 3.6L petrol auto, 2004. 92,000m
The seller has just (27.2.20) fitted a new throttle control sensor.
The engine management light is on and the gear changes are not as they should be (high revs [3000 before it changes] when pulling away).
Also, the overdrive is very, very slow to engage. 10+++ minutes!!!!
Does the computer need time to register the new sensor? Is the some trick to make the computer register the throttle sensor?
I have checked the transmission fluid - it does need topping up - but going to change filter, so will wait. Vehicle is not taxed, so not in use.
Thanks in advance for any help and advice.
Esorlegin is offline
post #2 of 7 Old 02-28-2020, 07:05 AM
jtec
jtec's Avatar
2014 JK Wrangler
ok the check engine light (third world - engine management light) is on SO there is a issue and step 1 would be to get codes and post them here.
jtec is offline
post #3 of 7 Old 02-28-2020, 10:40 AM Thread Starter
Esorlegin
Just finished grouting kitchen - codes is my next task.
Thanks for responding.
post #4 of 7 Old 02-28-2020, 10:53 AM
222Doc
222Doc's Avatar
3.6? i dont think. think its a 3.7. Huge difference. First one is a dual over head cam, VVT. the latter is a push rod v6. Might be wrong but i am about sure the 3.6 come in down road much latter then 2004. more like 2010/11.
222Doc is offline
post #5 of 7 Old 02-28-2020, 11:35 AM Thread Starter
Esorlegin
My booboo - it's a 3.7 - typo.
Just tried the key 'trick' to get codes....... tried all the various possibilities - passenger door open, driver door open and both doors open - nothing. It will not show error codes.
My first Jeep a few years ago - no problem got the codes up straight away, second Jeep, same - now this one will not 'play ball' !!!
post #6 of 7 Old 02-29-2020, 06:43 AM Thread Starter
Esorlegin
OK - finally got the error codes: P0068 & P0137
The exhaust is blowing and may need replacing - this could (??) be causing the error codes and over-revving before gear shift? May also have to get a new Lambda sensor & Cat - will know once exhaust is sorted.
Not so clear on Throttle position - a new sensor has been fitted (by previous owner) - I will check fixings. "Possible Vacuum leak" - I have no idea what this might mean.
Any advice appreciated.
Thanks Guys
post #7 of 7 Old 02-29-2020, 07:10 AM
jtec
jtec's Avatar
2014 JK Wrangler
the p0068 is likely the issue with trans shifting. SO confirm MAP readings also,
GTG later
P0068 MAP Sensor/TP Sensor Correlation
jtec is offline
