Problem with A?C in Liberty 2002 - JeepForum.com
post #1 of 10 Old 04-26-2007, 09:06 AM Thread Starter
tstream
Guest
The A/C will work fine for 15-20 minutes then it will blow out luke warm air, if I shut the A/C off for a minute or two then turn the A/C back on it will blow cold air again, any suggestions? Liberty 2002 sport, 6 cylcinder, 3.7.
tstream is offline
post #2 of 10 Old 04-26-2007, 11:03 AM
BVCRD
Compressor might be getting hot and shutting down. Might be a switch or something mis-directing air flow and it is turning the heater on. Just guessing here.
2006 Jeep Liberty Sport CRD
BVCRD is offline
post #3 of 10 Old 04-28-2007, 12:26 PM
Flynjp
Flynjp's Avatar
2011 JK Wrangler
Might need a few more details to make a good guess. Is the compressor running all the time for the 15 or 20 minutes or is it cycling on and off? If it is running all the time your evaporator could be icing up. Does the airflow get lower as the air temp gets warmer? This could indicate an icing up evap. When you shut the A/C off the evap de-ices and is then good for a while again. I'm not sure what cycles the compressor on and off on these Jeeps. It is probably a low pressure control on the suction side of the system. If this control won't open at the proper pressure, you will get an icing problem. I'm going to go look under my Liberty's hood to get a better idea.
Flynjp is offline
post #4 of 10 Old 04-28-2007, 06:23 PM
rob92xj
1992 XJ Cherokee
We have had a few KJ's at the dealership with a very similar problem and it is the AC compressor clutch needs to be re shimmed as the air gap is too large and the clutch cannot engage properly.
rob92xj is offline
post #5 of 10 Old 04-29-2007, 09:15 AM
Flynjp
Flynjp's Avatar
2011 JK Wrangler
The compressor clutch would be a good place to check for sure. Its hard to say exactly what is going on without having a set of gauges hooked up to the system to give us the operating pressures. How clean is the condenser? The comp could be tripping off because of high head pressure. The comp. could be stopping because of a bad comp. clutch coil. You may have to find somebody with a set of gauges to check out the pressures for you.
Flynjp is offline
post #6 of 10 Old 04-30-2007, 08:21 AM Thread Starter
tstream
Guest
Problem with A?C in liberty 2002
When the AC is on the air flow stays consistently the same and when the cold air stops comming out the air flow stays the same the air is just not cooled, but it is not hot either.When I turn the AC back on after 2 minutes the air is cold again
tstream is offline
post #7 of 10 Old 05-04-2007, 05:30 PM
Flynjp
Flynjp's Avatar
2011 JK Wrangler
It is still hard to say for sure without seeing the vehicle in person. It sounds to me like something is making the compressor cut out. What can do this? The high pressure cut-out switch can if the head pressure is getting too high. DO NOT, I repeat, DO NOT jumper this switch out to see if it is the problem. It is in the system for a reason. I'm not sure, but I am willing to bet that the compressor coil is fed from a relay somewhere. Maybe the relay is bad. Lots of possibilities. The main thing to look at is how the compressor is cycling ( how often, how long). You should find someone to put a set of gauges on it and check the system out.
Flynjp is offline
post #8 of 10 Old 09-24-2015, 08:11 AM
AZLIbertyDriver
had exactly the same symptoms with 2002 Jeep Liberty. I live in Scottsdale, AZ, so it was definitely a problem. Replaced the Freon and it has been good for 4 years now. Cheapest place to start. Good luck.
AZLIbertyDriver is offline
post #9 of 10 Old 05-15-2017, 07:30 AM
bbc454
Clutch smoking when I turn on the air
My compressor is making grinding noise when I turn on the air. I had my dad take a look at and he notice when I turn the air on the clutch started to smoke. He instructed me to not run the air until I can get it fixed. Can the clutch be fix or do I need another compressor?
bbc454 is offline
post #10 of 10 Old 05-21-2017, 05:01 PM
streetglideok
2005 KJ Liberty
Clutch won't fix that. Your compressor is locking up from the description, and the clutch is the weakest link. In order to correct the issue, and not spend a fortune chasing parts, you'll need a compressor w/clutch, accumulator, orifice tube, condenser, and then a flush of the a/c lines and evaporator. Install the correct pag oil and have it evacuated and charged correctly. Make sure you're electric fan is working correctly.
streetglideok is offline
2002 Liberty Radio problem photojames1968 KJ Liberty Forum 2 09-22-2014 09:24 PM
2002 Liberty Blower speed problem tutelo161 KJ Liberty Forum 1 06-21-2009 07:22 AM
PROBLEM W/ AC 2002 Liberty Limited AJ7 KJ Liberty Forum 6 05-05-2007 08:26 PM
2002 Liberty Electrical Problem bobbyorr KJ Liberty Forum 4 03-16-2007 08:07 AM
2002 Liberty 4x4 3.7 BeanGirlsJeep KJ Liberty Forum 3 08-05-2004 08:41 AM
