Part time light is on in 2wd not in 4wd - JeepForum.com
 2Likes
  • 1 Post By COLORADO
  • 1 Post By oop
post #1 of 11 Old 09-30-2009, 11:49 PM Thread Starter
wes3312000
Guest
I have a 2005 liberty used it in 4 lo and 4 hi and went to put it in 2wd and the part time light stays on .. I put it in 4wd hi and the light goes off.. Any ideas
wes3312000 is offline
post #2 of 11 Old 09-30-2009, 11:51 PM Thread Starter
wes3312000
Guest
and what is the difference in kj librty and kk liberty
post #3 of 11 Old 10-01-2009, 07:59 AM
COLORADO
I had the same problem. Failed switch on the transmission. Dealer charged $80 to replace it.
Brad426 likes this.
COLORADO is offline
post #4 of 11 Old 10-01-2009, 08:09 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Try putting the vehicle in neutral and coasting under 5 Mph and switch it from 4 LO to 2WD or turn the vehicle on without starting it and switch from 4 LO to 2WD. This should work
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #5 of 11 Old 10-01-2009, 10:00 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Originally Posted by wes3312000 View Post
and what is the difference in kj liberty and kk liberty
The KK is the 2008 and newer model, a different look. KKs use a new manufacture for the transfer case that has an electrical switch selector and an electric motor in/on the case. The Command Trac IIs are basically the same part time case as before but the Sec Trac IIs are a lot different, with automatic, so called active FWD switching
ColdCase is offline
post #6 of 11 Old 10-01-2009, 08:12 PM
ginn7
Guest
I had a similar problem today. Now when I am in the 2wd drive position (all the way forward, it says "part-time", when I am in the Partime (second postion back) it reads "Full Time". When I am in the usual full time position (3 up) it does not read anything.
My question is which is correct the lights or position? I heard that driving it in parttime on dry pavement is really bad so I am very concerned about this.
I want to avoid this until i get it fixed.
ginn7 is offline
post #7 of 11 Old 10-07-2009, 04:54 AM
kvenner
2002 KJ Liberty
Mine does the same thing. I wheel it hard, and the lights work as they should. Next time I wheel it, they are backwards. I don't worry about it. Go with the position of the shift lever, not the indicator light. Most likely its a flakey switch on the t-case, as stated above.
kvenner is offline
post #8 of 11 Old 03-24-2016, 04:38 PM
oop
Indicator light fixed-- here's how
Wife's 2005 Liberty had same problem after she was playing in 4lo to get through some snow in reverse.
After trying some other suggestions on this forum, the thing that worked in fixing the indicator light problem for us was:
- Put car in 2wd (lever all the way forward)
- Put car in reverse, got it moving to 2-3 miles an hour
- Depressed clutch, moved gear from R to neutral position
- With clutch in and while car was still coasting at 2-3 mph, moved TC lever from 2wd all the way to 4lo
- Continued back 5-10 ft
- Stopped
- Drove forward (1st gear) 5-10 feet, stopped again
- Got coasting 2-3 mph again in reverse, then depressed clutch, shifted from R to neutral, then moved lever from 4lo all the way to 2wd.
- Bingo! 4wd indicator light is now behaving as it should.
robbvant likes this.
oop is offline
post #9 of 11 Old 12-12-2017, 05:00 PM
robbvant
Hi just wanted to thanks you. your process worked perfectly. mine was automatic transmission but same steps. Had to do it 3 times cause i didnt fully engage the 4LO the first time.
robbvant is offline
post #10 of 11 Old 12-19-2018, 11:21 AM
stevenp1955
Transfer case position sensor failure
I have a 2003 Jeep Liberty 3.7L which had the same problem. I know this is a late response, but the dealer replaced the transfer case position switch which had a recall on it that I was unaware of. Works perfectly now. Check with your dealer for recalls.
stevenp1955 is offline
post #11 of 11 Old 07-15-2019, 06:35 PM
Tatharii
Ive got a 2002 Wj grand cherokee i had the part time light come on in 2wd and it goes off in any other setting. i replaced the transfer case switch and tried it again and its still on so im confused any help/ suggestions
Tatharii is offline
Part time light on luke179 KJ Liberty Forum 5 09-06-2011 08:51 PM
Part Time 4x4 Light On CarolinaKJ KJ Liberty Forum 8 02-21-2011 07:57 PM
part time light on when not in part time ytt1300 KJ Liberty Forum 10 01-23-2011 11:30 PM
I'm in 2WD but the part time light is on and I have no clue :) STSMWR KJ Liberty Forum 15 01-20-2009 10:52 PM
Part time light on all the time sharhack KJ Liberty Forum 2 07-31-2007 09:58 AM
