jeep liberty - JeepForum.com
 2Likes
  • 2 Post By mukluk
post #1 of 4 Old 08-19-2019, 01:10 AM Thread Starter
gks1965gto
jeep liberty
I replaced the tranny solenoid in a 2006 jeep liberty and when i put the valve body back up in place and the bell crank shaft went into place nicely and I tried to put the bracket (shift linkage #10 below) on top of the bell crank while in park and it will not go on at all. I messed around and put the shifter in drive and it slipped over the top nicely but the shifter would not go into park or 1 or 2nd gear...ughh, its just too hard to do. If I unhook the linkage and put the shifter back in park and try to rehook up the linkage, it will not go on, almost but will not slip over the top...just too frustrating. iT
gks1965gto is offline
post #2 of 4 Old 08-19-2019, 05:54 AM
rcroane
This is the TJ forum.....you need to post this in the Liberty forum.
rcroane is offline
post #3 of 4 Old 08-19-2019, 07:24 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
KJ forum is that way >>>>>>>>>>>>>>>>>
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #4 of 4 Old 08-19-2019, 12:01 PM
mukluk
mukluk's Avatar
The removal instructions state to turn the manual shift shaft one position past L before removing, so it would make sense you need to rotate it back to the same position to reinstall the bracket. It sounds like you're trying to do so at the opposite end of its travel (at Park).
TheBoogieman and Brad426 like this.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
