[Help] white smoke and burning smell, Valve cover gasket? + other advice - JeepForum.com
post #1 of 22 Old 03-06-2014, 07:42 PM Thread Starter
omega48er
Hi guys,
I just recently purchased my 03 jeep liberty with 97k miles on it. LOVE IT now i never owned a vehicle (or jeep) with that many miles, my first car was a lease and my other cars were purchased with less than 20k miles on it, so im a little scared owning a car with this many miles.
Problem: there is a burning smell in the cabin and there was a light white smoke coming from the engine compartment. when i opened the hood i saw smoke from the passenger side behind the engine, i believe what looked like the CAT converter. also, there was smoke escaping from the front passenger headlight. could this be 2 problems, 1 being the gaskets and the other the radiator?
the Jeep does not run hot, never passes the halfway mark on the gauge.
if someone could confirm this is a problem is related to the valve cover gasket.
also, if the radiator is also going can i replace it with the Spectra CU2481 Radiator?
as for the Gasket, can i use FELPRO VS 50594 R Engine Valve Cover Gasket Set?
while i was at it, i was thinking of doing the Serpentine Belt and was looking at using the Goodyer Gatorback 4060875
Now for some other info.
i do not drive much, when i leased my civic i drove less than 24k miles in 3 years.
other maintenance:
i purchased Autolite copper plugs (still needing install)
Purchased Mobil1 10w30 Highmile full synthetic oil with new air filter and Mobile1 High performance oil filter.
Is it a smart idea using the synthetic oil? also, should i do the oil change before or after i do the Valve cover gasket?
I attached 2 pictures that show where the smoke was coming from (circled in yellow)
Thanks for all of your help.
2006 Jeep Commander HEMI - GONE
2010 Jeep Commander HEMI
omega48er is offline
post #2 of 22 Old 03-06-2014, 08:01 PM Thread Starter
omega48er
now that i think about, when i turned the engine off i might have heard some droplet sounds, so im strongly thinking that there is a gasket leak and its falling on the exhaust manifold.
once someone confirms it i will go ahead and purchase one and DIY it,
so will the FELPRO VS 50594 R Engine Valve Cover Gasket Set work or, should i look at another one?
almost forgot, i ordered a PVC valve, is there anything else i should look at.
please do keep in mind this is on a budget since i just quit my job not too long ago (college student)
post #3 of 22 Old 03-06-2014, 10:31 PM
KJ2Life
2002 KJ Liberty
Are there any leaks in the coolant resivoir? It's a possibility that you could be leaking coolant on to some hot spots. (Hence the smoke) check if you're burning coolant as well.
KJ2Life is offline
post #4 of 22 Old 03-07-2014, 06:02 AM Thread Starter
omega48er
^Thaks kj2life, I will look for coolant leaks as well
post #5 of 22 Old 03-07-2014, 10:04 AM
KJ2Life
2002 KJ Liberty
No problem, keep us posted on progress!
KJ2Life is offline
post #6 of 22 Old 03-07-2014, 02:04 PM Thread Starter
omega48er
alright,
So, i popped the hood and the first thing i did was change thsoe dead hood shocks. now i took your advice and checked out the coolant and guess what ITS GREEN! so, the previous owner was using the wrong coolant, awesome!
then i checked the oild and it looks dirty and low, so its time to change that .
what im doing today: changing the oil and spark plugs
tomorrrow (or if i have time today) draining the coolant and replacing it with Zerex GO5.... should i run any flush cleaner through it? something like the Zerax super flush?
Thanks
post #7 of 22 Old 03-07-2014, 02:11 PM
KJ2Life
2002 KJ Liberty
Definitely flush the system! There is no telling what it may cause in the future.
KJ2Life is offline
post #8 of 22 Old 03-07-2014, 07:22 PM Thread Starter
omega48er
when i placed my order with advance auto parts i also picked up the valve cover gasket, it came out to 35 dollars so it was a good buy.
this jeep is turning me into a little mechanic.
could someone else also chime in on my situation? it was too cold here today (new york) to do any work, but tomorrow is suppose to be nice.
post #9 of 22 Old 03-08-2014, 02:37 PM Thread Starter
omega48er
hay guys,
So after taking some things apart i found these 2 pieces to be cracked. can someone id them and give me the name and part number?
post #10 of 22 Old 03-08-2014, 04:35 PM Thread Starter
omega48er
ok, so the smoke appears to be gone. i will report back on that after i go for a drive.
what i did:
changed the oil, that ***** looked black as night, i replaced it with some Mobile 1 synthetic high miles
Changed the spark plugs with some autolite copper.
while i had the air box out, i decided to take it all off and clean out the throttle body, that thing had its fair share amount of dirt on it.
put in a new air filter.
now, if someone can please id those 2 parts for me so i can replace them. thanks!
post #11 of 22 Old 03-08-2014, 08:05 PM
KJ2Life
2002 KJ Liberty
I doubt there is a part number for the hoses. If I were you I would drive it to the local autoparts store and see what kind of hosing they have to replace those.
KJ2Life is offline
post #12 of 22 Old 03-09-2014, 07:14 AM
Gizmalien
2004 KJ Liberty
Originally Posted by omega48er View Post
hay guys,
I had to replace mine after I broke it while replacing my valve cover gaskets, part number is 53013723AC, I found it at http://www.factorychryslerparts.com/...3013723AC.html
Gizmalien is offline
post #13 of 22 Old 03-09-2014, 07:39 AM Thread Starter
omega48er
hay Gizmalien,
Thanks for that! is that part # also, does that hose come with the silicone piece that connects the hose to the intake box? i really just need the siicone part but changing the whole pipe should not hurt
Thanks again. also, any idea on what the other silicone piece is that connects to the t-connector?
post #14 of 22 Old 03-09-2014, 07:49 AM
Gizmalien
2004 KJ Liberty
It's the entire assembly, from engine to air box, with the connectors.
post #15 of 22 Old 03-09-2014, 09:16 AM Thread Starter
omega48er
completely missed your comment. will stop by Advance auto or NAPA
