AC Clutch won't engage - JeepForum.com
post #1 of 4 Old 05-16-2019, 11:11 AM Thread Starter
nfmous
It's vacuum'd down and I was able to charge it by bridging 87a to 30 on the relay. It blows cold air, but it won't run no matter what unless I bridge the relay pins.
I've checked the low side pressure switch getting voltage there, but jumping it doesn't make the compressor come on.
I've checked all the fuses, swapped relays. Can't figure it out
nfmous is offline
post #2 of 4 Old 05-16-2019, 12:05 PM
jtec
2014 JK Wrangler
what year and engine?
Did you ck codes even if light is off?
Do you have AC gauges?
jtec is offline
post #3 of 4 Old 05-16-2019, 12:49 PM Thread Starter
nfmous
Yeah I have gauges, no codes
Jumping the low pressure switch plug doesn't do anything, I cut it off and wrapped the wires together and the compressor kicks on.
So I know the plug is bad
nfmous is offline
post #4 of 4 Old 05-16-2019, 01:54 PM
jtec
2014 JK Wrangler
X2 what year and engine?
you did use a scanner to check for codes?
What is the static pressure?
jtec is offline
92 yj clutch won't engage? jarrodblake YJ Wrangler Technical Forum 4 11-20-2018 05:02 PM
Clutch Wont Engage ayelander TJ Wrangler Technical Forum 4 10-07-2018 05:29 PM
Clutch noise when engine is cold... Josh06LJ TJ Wrangler Technical Forum 4 05-16-2018 06:46 AM
Clutch change observations JEK3 TJ Wrangler Technical Forum 3 02-17-2018 05:49 PM
Anyone Running Wilwood Clutch Master? Group_er Jeep CJ Forum 20 01-21-2018 02:06 PM
