Ac clutch relay keeps blowing - JeepForum.com
post #1 of 6 Old 03-28-2020, 03:11 PM Thread Starter
BogoMIPS
BogoMIPS's Avatar
2003 KJ Liberty
03 Liberty
4WD
V6
My ac clutch stopped working so I replaced the relay.
I ordered one with the exact name and p/n.
A month later it failed again.
It sat for a few months before the ac issue.
What could be making the relay fail after a few weeks?
The clutch?
The compressor?
Something else?
BogoMIPS is offline
post #2 of 6 Old 03-28-2020, 04:04 PM
jtec
jtec's Avatar
2014 JK Wrangler
Could the AC be over cycling, the clutch drawing to many amps?
jtec is offline
post #3 of 6 Old 03-28-2020, 04:50 PM Thread Starter
BogoMIPS
BogoMIPS's Avatar
2003 KJ Liberty
I will look at my service manual and check how many amps it's pulling. It did seem to be cycling on and off a lot. Thank you and will keep you updated
BogoMIPS is offline
post #4 of 6 Old 03-28-2020, 06:13 PM
jtec
jtec's Avatar
2014 JK Wrangler
The compressor clutch coil is acceptable if the
current draw measured at the clutch coil is 2.0 to 3.9
amperes with the electrical system voltage at 11.5 to
12.5 volts. This should only be checked with the work
area temperature at 21 C (70 F). If system voltage
is more than 12.5 volts, add electrical loads by turning on electrical accessories until the system voltage
drops below 12.5 volts.
(a) If the clutch coil current reading is four
amperes or more, the coil is shorted and should be
replaced.
jtec is offline
post #5 of 6 Old 03-28-2020, 09:17 PM Thread Starter
BogoMIPS
BogoMIPS's Avatar
2003 KJ Liberty
replaced.
Thanks for that info.
Tonight omw to work I set the ac to recirculate, and it was blowing cold air for about 10 minutes. I did notice that the clutch was still cycling on and off. Approx 5 second intervals. I won't have time till Monday to put the meter on it.
BogoMIPS is offline
post #6 of 6 Old 03-29-2020, 02:13 AM
jtec
jtec's Avatar
2014 JK Wrangler
fast cycling - Low on refrigerant (suva) ? I am thinking of an easy way to confirm refrigerant charge, only thing I think is remove and weigh - not an easy DIY test.
jtec is offline
