2005 Liberty Help - JeepForum.com
post #1 of 6 Old 07-31-2015, 06:30 AM Thread Starter
MW1994
2005 Liberty Help
Hello,
I have a 2005 Jeep Liberty Sport.
I have a whining noise coming from the front area of my vehicle whenever I am accelerating/applying gas. Faint at lower speeds, but more noticeable once I hit the highway. It completely goes away once I stop applying gas. Any idea if this is a major/minor issue, what can be causing it, or how to fix??? The whining sort of sounds like the automatic paper towel dispensers in the public restrooms, but consistent. Haha
MW1994 is offline
post #2 of 6 Old 07-31-2015, 08:52 PM
02blue
2005 KJ Liberty
Really need to fill in your profile to get to the point quicker. Is this a 4wd??? IF SO, Does it get worse of better in 4wd? Check all the fluids, Differentials, tcase and tranny. Also check the front driveshaft. There are CV joints on both end that can fail. Look for cracked boots. The rear one has a recessed boot that is very difficult to see and will often fail without much warning. It can make a sorts of sounds and usually causes a vibration and noise under load/acceleration.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is offline
post #3 of 6 Old 08-01-2015, 06:42 AM Thread Starter
MW1994
Thank you, and will do. It's a 4wd. I will check and test everything out you suggested today after work. Hopefully I will find the source of the noise.
Much appreciated.
MW1994 is offline
post #4 of 6 Old 08-03-2015, 09:34 PM
Mikey37
2005 KJ Liberty
Typically whining can be sourced to bearings of some kind but a number of things make these noises. Sometimes other noises can be heard if you have someone drive slowly along while you follow listening for other indicators like loud clunks, clicks or pops. Prop the truck up on a jack and jack stands and grab the tires and wiggle them like your trying to take it off and feel for any wobble that is what you would consider a bit much.....a tiny bit of play may be felt but if it feels excessive then you have a potential wheel bearing problem. I would also check for tightness in your wheel lugs...are they torqued? The key is to try and pinpoint the area of the problem because while driving, noises reverberate and what you think is coming from the front might actually be the back. I hope this helps a bit...good luck
Professionals built the Titanic, amateurs built the Ark.
Mikey37 is offline
post #5 of 6 Old 08-03-2015, 09:52 PM
Mikey37
2005 KJ Liberty
Here is a list of possible suspects if you do find your noises coming from the tail end. http://www.onallcylinders.com/2012/0...veline-noises/
Mikey37 is offline
post #6 of 6 Old 08-04-2015, 11:24 AM Thread Starter
MW1994
-Mikey37
Thanks I will be doing a detailed search for the cause of the whining today or tomorrow and will check the parts you've advised.
MW1994 is offline
