07 3.7 Starts but won’t keep running without my foot on the gas. - JeepForum.com
post #1 of 3 Old 10-19-2021, 02:31 PM Thread Starter
Pkschram85
The other day the old girl died right when I pulled In the drive way. Pulled the battery and charged it overnight. It’s holding a charge and it’s a fairly fresh battery. I replaced all the plugs and air filter checked all vacuum lines and replaced any hose that had a leak.
As it sits right now it’ll start right up and run but only with my foot on the throttle. So it’s not moving from its spot.
I’ve looked for the AIC and TPS but I think they’re part of the throttle body on this unit? Should I go ahead with replace the throttle body or start looking else where. Any help would be welcome. Thank you.
Pkschram85 is offline
post #2 of 3 Old 10-19-2021, 02:47 PM
kueh
2007 KJ Liberty
Did you try a different key? It could be the security thing not working.
Sent from my LM-V600 using Tapatalk
kueh is offline
post #3 of 3 Old 10-19-2021, 03:12 PM Thread Starter
Pkschram85
Unfortunately this is the only key I have. Is there a way to resync the fob or go around it if that’s the issue?
