03 Liberty 3.7L random misfire FIXED! - Page 2 - JeepForum.com
 2Likes
post #16 of 25 Old 11-30-2015, 10:20 AM
jhcarrasco
Usaf retiree
Thanks I will try that replace the
relay and get back to you all.
jhcarrasco is offline
post #17 of 25 Old 12-11-2015, 07:50 PM
Nick1234
2006 Jeep Liberty 3.7L
My wife's 06 Liberty is throwing a P0300 multiple misfires code. I cannot find anything for the 06 that is a Auto Shutdown Relay. Is there something I am missing?
Nick1234 is offline
post #18 of 25 Old 12-11-2015, 11:57 PM
Billwill
2002 KJ Liberty
The ASD relay is in the relay box under the hood...the plastic cover for this box shows where the components are located.
Misfires can be caused by bad injectors, wrong spark plugs if it is a gasser or the timing is a tooth out, cam or crankshaft sensors.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #19 of 25 Old 12-14-2015, 12:26 PM
DrRedRanger
I'm having a stubborn misfire problem too; maybe you guys might have an idea? So a 2003 liberty, 3.7L, and it started throwing misfire codes after intermittently running rough and shaking. Ran some codes, saw multiple misfires and vacuum leak, so I went through the process of replacing the spark plugs, coil packs, using fuel cleaner, getting the injectors, current, and compression checked, all to no improvement. The problem is now persistent and isolated to cylinder one; it perpetually and reliably misses, causing the vehicle to shake rhythmically, running rough when idling or driving on the highway, and in some cases stalling out when coming to a stop. The only thing I haven't looked into would be the vacuum leak, but I'm not sure what tubes to check that for, or what they look like/where they are. Any thoughts?
DrRedRanger is offline
post #20 of 25 Old 01-19-2016, 05:50 PM
T's '97TJ
I have Multiple misfire codes and have had them for about as long as my AC compressor's been out. The Jeep runs great btw. Sounds like a super long shot, but any chance their's a correlation? 1997 TJ 4.0. If so, would I unplug the ASD and or the AC compressor connector? Or replace the ASD relay?
"Children will not remember you for the material things you provided but for the feeling that you cherished them."
T's '97TJ is offline
post #21 of 25 Old 06-17-2016, 07:24 AM
GEISHAM
Where can l buy and how much for the ASD?
GEISHAM is offline
post #22 of 25 Old 06-17-2016, 10:01 PM
streetglideok
2005 KJ Liberty
try a parts store?
streetglideok is offline
post #23 of 25 Old 01-25-2019, 01:10 PM
Stupid Jeep
It Worked!!! on a 2002 GC 4.7
Originally Posted by timofthejeep View Post
Well, here is my story. It all started 4 months ago. engine light and misfire. I did all the obvious, coils, plugs, computer, cleaned injectors, no help. I fought the thing all winter. Problem would come and go. Random misfires (p0300, P030x, P035x), the codes listed at times 12 different codes. They would come and go. The problem would move around. I started getting desperate. The battery was weak, so I changed it thinking it would cause a weak spark. Checked fuel pressure. It was OK. Vacuum leaks. Fixed them all. Nothing helped. Then the other night I was reading the Haynes manual in a completely different section... It mentioned the one thing that I had missed. (read on...)
It was late, so I called it quits for the night. I went to the shower smelling like I has spilled the gas can on myself. I was so frusterated. I know I am not that smart, but I AM smarter than a danged car... I thought to myself. So I started thinking about it. What could cause a random problem that comes and goes? It has to be something COMMON to all the COILS. I started thinking about how the voltage gets to the coils to cause the spark. Battery positive to fuse to ASD relay to coil positive to PMC to ground... what??? ASD RELAY?!?!? Here is the ONE THING that is common to all coils, and if it is weak or the contact is worn can cause a weak spark by not supplying enough power to the coils... It is not mentioned as an integral part of the ignition circuit. It is not out in the open where it tcan be easily seen. Out of sight out of mind. So I changed it. The misfire immediately went away. Within 2 hours the light went out. It has more power than it had in ages. Mileage better, too (thanks to the fixed vaccuum leaks no doubt.). CHEAP FIX that costed me a small fortune!!! ASD relay in the engine compartment fuse box. Tell all your friends!!! ASD RELAY!!!!
DUDE!!!! Thank you so much for posting this. I have a different model jeep it's a 2002 GC Laredo 4.7 my jeep ran smooth and for some reason I couldn't get the check engine light to go off (random misfire codes). Replaced the plugs and coil pack and cam position sensor to no avail... I couldn't get the light to go off to get through emission testing... Anyway I just did this and BAM! light went off passed emissions. Jeep is tip top. Thank you!!!!!!!!!
Stupid Jeep is offline
post #24 of 25 Old 02-03-2020, 02:46 PM
lowderjr
Just had one today like this. While driving or holding the accelerator it would misfire on ALL cylinders. I also noticed ALL 4 oxygen sensors would drop out at 0V. It was the ASD relay.
lowderjr is offline
post #25 of 25 Old 02-13-2020, 08:46 PM
lowderjr
ASD relay didn't fix it. Just a fluke when I removed it and the misfire went away.
lowderjr is offline
jeeptorino68
Liberty Cylinder Misfire / Computer issue? Rach KJ Liberty Forum 37 03-20-2016 11:22 PM
intermittent misfire (P0306), 2002 Liberty 3.7L V6 jtustaniwskyj KJ Liberty Forum 8 04-17-2015 10:18 AM
02 Liberty misfire whammer33024 KJ Liberty Forum 17 03-01-2010 11:54 AM
2002 Liberty Misfire. Dealership can't figure out, can anyone else? ransom KJ Liberty Forum 10 11-18-2006 07:20 AM
2003 Liberty Ck Engine Light Misfire Carolina Rider KJ Liberty Forum 4 08-02-2006 12:46 PM
