Wk 4.7 engine swap Jeep Registry
Previous Jeep WK Grand Cherokee Next Jeep
Wk 4.7 engine swap
Email Bookmark Print
Muddman11
Kokomo
Jeep Information
Okay so I've got a 2005 WK I picked up and the motor is toast. No questions about it. I pulled the head and the engine had a broken wrist pin and dropped a valve. So I knew someone who had a spare 4.7 engine laying around so I took it off his hands. After doing some research I'm not so sure I'll be able to use it. The motor came out of a 2000 WJ. Am I correct on this or? Also if the new motor I have isn't compatible what other make and model vehicles can I snag a engine out of? And lastly while I'm in the process of swapping out engines what recommendations do you guys suggest replacing while I'm in there. Timing and head gasket of course, rear main seal ext....
Thanks in advance!
None
