pit-prop Jeep Registry
Previous Jeep WK Grand Cherokee Next Jeep
pit-prop
Email Bookmark Print
pit-prop
Jeep Information
Year:2007
Model:Grand Cherokee Overland
Engine:3.0 CRD
Transmission:Standard
Transfer Case:Standard
Front Axle:Standard
Rear Axle:Standard
Axle Gear Ratio:Standard
Suspension:Standard
Tires:Standard
Wheels:Standard
Armor:N/A
Recovery Gear:Toe bar
Accessories:Standard
Hi
I have a swirl motor issue. The ETC light came on and later the MIL and my Jeep went into 'Limp' mode.
After reading a few threads on here I did the 4.7K resistor mod. This took off the ETC light and normal acceleration was restored but the MIL light remained on.
I bought a Bluetooth OBD2 scanner and found code P2008 was causing the MIL indication.
Reading what the code means on obd-code.com is frightening.
Has anyone had this before and solved the problem please?
None
Login Or Register To Post Comments
