Crank no run😞 no key light solid not flashing, besides fuel pump also not working is passenger windows, ac compressor, & only thedriver door lock not working electrically.. I've read that grounding the PCI wire to the chassis can solve the immobilizer problem, stopping it from thinking I'm using the wrong key. Is the wire yellow with violet pin stripe on my 04 WJ Overland?? Or did the wire change colors in mine's generation?? Pleas help😁
